Ive got this amp up on the bench which has probably seen better days. The owner insisted on keping the cover to this amp while I try to fix it - because he was going to clean it up and get it powder coated if I can fix this for him. This poor amp has definately been through some physical battles and has likely suffered death from foreign debris.
Lucky for this amp, none of the fets are measuring shorted so i believe this will be a low-cost but time consuming affair. I believe CT for this amp is at one end of the large resistor-pack "attenuation" module - however, only one of the two resistors is of good reference (1vDC referencing amp ground) because the other is measuring 9vDC referenceing amp ground. The amp powers up with +-41.5vDC on the sub/mono rail and +-29.5vDC on the other channels. Opsamps are getting +16.5v and -18.25v... The + Left Front and + Left Passive terminals have -8vDC on them, and + Mono speaker terminal has +8vDC on it. Using my eagle eye, I found several visually defective areas on the board: R183 missing (10 ohm?), R132 (100 ohm), R176 (1k ohm), and Q78/Q79 (1BZ?): ![]()
#2 |
#3 |
Yes. The resistor is 10 ohms. The transistors are marked 1B 2.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
#5 |
XTant X603
Amplifier because the impact had asked you Will the picture on the black circle with part of the value of that? ? ? Thank you |
| Help with Xtant x603 | shawnk | Car Audio | 50 | 15th February 2010 05:03 AM |
| xtant x604 | mike49504 | Car Audio | 3 | 13th January 2009 05:23 PM |
| Xtant X1001 | Bgun | Car Audio | 18 | 5th November 2008 02:49 AM |
| Xtant 3150c | kelwin | Car Audio | 4 | 23rd October 2007 09:58 PM |
| help for xtant 3300x | av973 | Car Audio | 5 | 17th December 2006 11:02 PM |
| Page generated in 0.07523 seconds (73.59% PHP - 26.41% MySQL) with 11 queries |
