Go Back   Home > Forums > General Interest > Car Audio
Old 1st May 2011, 04:59 PM   #1
Default pyramid ps-46kx power supply
i bought this power supply new several years ago and shortly after i got it the current meter starting acting up. it for the most part is non responsive, if i tap on it some times it will jump around but will hardly ever start working properly. this has been a pain for years and now i'm getting tired of it. the other day perry asked me how much current a particular amp was drawing and i had to pull out my power supply, take the cover off inspect it and see if i could find a problem. i saw nothing obvious that was wrong but there is something. when i put it back together it worked like new for a few hours and now it is worse than before. when it stopped this time i did nt pull the power supply apart i just tapped it a few times and now the lights for both my meters have stopped working!!! the voltage meter has never given me any problems nor has the actual power supply. i have noticed that if i put a signifigant load on the power supply (30+ amps) the current meter will sometime be responsive. has anybody had this sort of problem before? should i try to replace the current meter?
Old 1st May 2011, 05:05 PM   #2
Post a photo of the back of the meters.
Old 1st May 2011, 05:19 PM   #3
3 pics
Old 1st May 2011, 05:20 PM   #4
1 more
Old 1st May 2011, 06:32 PM   #5
Disconnect one of the two center terminals completely from the power supply. Set your meter to diode check and touch the probes across the two center terminals (the outer terminals are for illumination). Does the meter swing every time you touch the probes to the terminals? If so, the problem is on the main board or a connection between the main board and the meter. The pots on the meter could be dirty or intermittent but that's less likely. If the meter swings the wrong way, reverse the probes on the terminals.
Old 1st May 2011, 07:20 PM   #6
the lights were out from a bad connection, i got that fixed. with one of the center terminals of the current meter disconnected and my multi meter on diode check the needle will jump around like you said. so i guess it's a bad connection somewhere else.
Old 1st May 2011, 07:51 PM   #7
i really can't seem to find any bad connections. maybe the heat from the solder gun had something to do with the current meter responding better now. the actual light bulb in the current meter is bad though. would it be okay to replace it with an led.
Old 1st May 2011, 08:14 PM   #8
Yes but you'll need to insert a current limiting resistor in series with the LED.
Did you try turning the adjustment pot on the meter to see if that made a difference?
Old 1st May 2011, 08:34 PM   #9
no, i didn't mess with the pot it is glued in place.
Old 1st May 2011, 08:56 PM   #10
Even if they have adhesive on them, you should be able to work them back and forth to see if the pots are dirty causing the meter to stop working.
Improving a Maple Tree Audio PS 2 power supply diamondsouled Tubes / Valves 19 7th January 2011 02:34 PM
Pyramid PS-15KX power supply Dr Zeus Car Audio 11 16th December 2010 01:08 AM
Welborne labs PS reg. 12v 1A. power supply. tweakk Swap Meet 1 11th October 2010 01:59 AM
Fore Sale - DIYZONE Power Supply Boards c/w All Parts except PS Capacitors dtm1962 Swap Meet 4 9th April 2009 12:27 AM
Pyramid Power cujo75 Subwoofers 17 23rd July 2008 06:55 AM
Page generated in 0.09630 seconds (80.08% PHP - 19.92% MySQL) with 11 queries
