i cant understand where my power is going i cant find it anywhere.
i have 12v on the center leg of the power supply and 12v on the torridial transformer. i also have 12v on the first leg of Q44. and the 3rd leg of Q45. other than this i cant find < .5v anywhere else and i cant see anything else burnt any ideas? i have 2 big caps that are 3300uF 35v and when i put my ESR meter on them they start super high around 4 and over ~1 min it drops to .07. is this normal? what does this mean? also i replaced the transistors in the blue boxes Last edited by scampo77; 28th April 2011 at 12:13 AM. |
#2 |
any output from the 494?
#3 |
Post the DC voltage on the 494.
Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14: Pin 15: Pin 16:
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
all legs are 0v
#5 |
What is the DC voltage on the thermal switch on the bottom of the board?
#6 |
its battery voltage on both sides ~13v
#7 |
There is an MPSA56 with its collector connected to pin 12. Post the DC voltage on all 3 legs.
#8 |
its Q44
E - 13V B - 13V C - 0V and i just changed this one a hour ago |
#9 |
There's an MPSA06 connected to the base of the A56. Post the voltage on it.
#10 |
the A56 at location Q44 is attached to a black strip thing with 8 pins on it that i have never seen before and i dont know what it is. the base (the middle leg) is attached to this thing. i tried to draw lines showing where everything goes to
MPSA06 location Q45 E - 0 B - 0 C - 13v i just want to make sure that according to my picture that the emitter is on the left the base in the middle and the collector is on the right |
| Old school Orion XTR 2250 | DanielJ | Car Audio | 28 | 28th October 2011 11:31 AM |
| Orion XTR 2250 OLD SCHOOL | wyteboy | Car Audio | 2 | 10th April 2011 10:54 PM |
| Orion XTR 1400 | NIM006 | Car Audio | 2 | 12th January 2009 02:11 PM |
| orion xtr 2150 | mike49504 | Car Audio | 11 | 1st October 2006 12:19 AM |
| need help with a orion xtr 400 | brax | Car Audio | 0 | 25th June 2004 07:26 PM |
| Page generated in 0.08876 seconds (78.31% PHP - 21.69% MySQL) with 11 queries |
