Hi all, looking for some advice on a JL Audio 800x1. I have a couple output fets bad(35n15g) in the output stage.
Should I be replacing all 8 with the same date code and do I need to do any setup for biasing? I`ve read a few post about adjusting a pot fully ccw and bringing it up till idle current increases slightly. There is a pot on a vertical board close to the fets and one on the opposite side of the amp. If I do need to do this adjustment which pot? Thanks Les |
#2 |
I don't think you need to mess with the pot, I had to replace those same fets in the same amp, was fine after I did it, I did replace them all though I think they are inexpensive so might be worth it. date code should not matter just check voltage and such, I got my fets from digi-key they worked great, almost forgot check the driver fets as well, I had to replace a couple of those, there is a jfet a j108 or j111 in there it will measure bad but it's normally not works when power is applied to it.
#3 |
this amp is the e1800 right?
#4 |
Found it on the side A 1800 class d Mono.
Looks like 300 minimum order from Digikey and they are non stock. I`m sure I can come up with them somewhere.... unless there is a good sub for them? |
#5 |
ah thats right they were being discontinued when I ordered them try mouser
#6 |
The outputs:
NTP35N15G for ON Semiconductor | Arrow Electronics Components Don't turn the pot fully CCW. This isn't a class AB amp. I think the one on the driver board is for the over-current threshold. The one on the main board is the DC offset.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
| Jl audio 500/1 powers on with low audio out help needed | ivkata | Car Audio | 29 | 19th August 2011 12:21 AM |
| Can I run a 10 inch JL audio and a 12 inch JL audio off same amp | ash4kel | Car Audio | 2 | 8th April 2011 02:12 AM |
| JL Audio 10w6v2 or Infinity Kappa 100.3se? Audison SRX4 or Jl 300/4? | DcMaN | Subwoofers | 1 | 17th September 2010 10:28 AM |
| jl audio | nicandjade | Swap Meet | 0 | 2nd September 2006 10:35 AM |
| Page generated in 0.08055 seconds (77.59% PHP - 22.41% MySQL) with 10 queries |
