Wondering if anyone knows what the correct part number is or what diode i could use.
This is an electronic crossover and the reverse polarity didoe is burnt and half of its missing. So just wondering if anyone knows what diode i could use in it? |
#2 |
Virtually any diode rated for 1 amp or more will work. The 1N400x diodes are commonly used.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
1N4004 is what i was thinking.
Is that a good choice for the diode? |
#4 |
Yes if it's comparable in size to the original.
#5 |
Ok I replaced the diode And when i try to power it up The power led will not light. Heres what i have on the 494
1:1.82 2:4.83 3:0.05 4:0.09 5:1.61 6:3.67 7:0 8:0 9:2.64 10:2.63 11:5.13 12:13.92 13:0 14:5.02 15:5.02 16:0 |
#6 |
The voltage doesn't look right. 8 and 11 should have the same voltage.
9 and 10 seem to be producing output. What are they using for power supply transistors?
#7 |
Only transistors i see in this Crossover are
D1062 C1815 |
#8 |
Assuming that there are two D1062s that have their collectors connected to the transformer, do you see pulses on the center legs?
#9 |
Theres only 1 D1062 in this unit
#10 |
Are the C1815s driving the transformer?
Did you check the op-amps to see if they had ±15v on their power supply pins?
| looking for MCS (Dantimax) | wuffwaff | Everything Else | 8 | 18th January 2011 04:53 PM |
| Accuphase MCS | Havenwood | Solid State | 3 | 15th February 2010 11:45 AM |
| majestic amps | ZippyTs | Car Audio | 5 | 28th October 2009 01:00 AM |
| Majestic Transformers | E810F | Tubes / Valves | 2 | 7th January 2009 09:35 PM |
| Majestic felix | MaXiZ | Car Audio | 0 | 21st October 2005 03:37 PM |
| Page generated in 0.08190 seconds (78.36% PHP - 21.64% MySQL) with 10 queries |
