Go Back   Home > Forums > General Interest > Car Audio
Old 22nd April 2011, 04:00 PM   #1
Default ADS PQ20
Im starting a new thread on this amp since the last thread says it was closed.
I got the amp to power up and stay powerd up now the amp had a blown trace on the output board.
The amp plays But there are a couple of problems.
1ST problem: when listing to the amp it sounds like the music has an echo to it.
2ND problem: I can hear a hum through all speakers connected to the amp with and without volume.
Any ideas?
Old 22nd April 2011, 04:05 PM   #2
Does it hum with no RCAs connected?
Is the signal source ground tied to the amp ground?
Old 22nd April 2011, 06:37 PM   #3
It hums with no rca's plugged in.
Signal source ground Do you mean the rca shields?
Old 22nd April 2011, 08:28 PM   #4
Yes if it's a portable player. If it's a head unit, the ground for the head unit would be the signal source ground.
Old 10th May 2011, 04:16 AM   #5
Ok back to this amp.Im going throught the entire amp top to bottom to get it to sound like brand new again.
Not sure what year this amp was made but wondering if it is a good idea to replace the caps in this amp due to age. If so wondering who makes the best caps out there? When i get this amp done i want it to be pure sound quality
Old 10th May 2011, 04:24 AM   #6
seankane's Avatar
Nichicon Muse are very nice caps to use.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 10th May 2011, 04:37 AM   #7
Cool thanks. Still wondering if there is a even better brand out there? I wanna rebuild this amp from the bottom up. Im looking to get the best sound out of it as possible
Old 10th May 2011, 04:44 AM   #8
Wondering If anyone has opinions on the Panasonic FC series caps?
Old 10th May 2011, 02:55 PM   #9
FC series caps are a good choice for power supplies. They can take more abuse than many capacitors. In this amp, there aren't any capacitors that will be under any real stress. Virtually any capacitor within spec will work. Assuming that all caps meet spec, using expensive capacitors or cheap capacitors won't make a difference in the sound quality.
Old 18th May 2011, 03:58 AM   #10
Im working on this amp still while waiting for parts for other amps.
Im almost done rebuilding the power supply section of this amp then its off to the output section.
My question is if 1 of the UPC1270H's are bad in this amp would that cause the humming through the speakers or cause the music to echo??
ADS PQ20 mike49504 Car Audio 2 19th April 2011 03:47 AM
ADS a/d/s Braun PQ20 with no output gisewhcs Car Audio 3 21st September 2010 12:45 PM
Wanted: A/d/s/ Pq20 Jonny Hotnuts Swap Meet 2 4th January 2008 07:58 AM
ads pq20 mike49504 Car Audio 3 8th August 2007 01:11 AM
ADS PQ20 amp- anyone worked on? GordonW Car Audio 1 24th March 2007 08:14 PM
Page generated in 0.09252 seconds (76.13% PHP - 23.87% MySQL) with 11 queries
