Go Back   Home > Forums > General Interest > Car Audio
Old 18th April 2011, 06:52 PM   #1
ash4kel is offline ash4kel  United States
Default Orion 250r blowing fuses
I had a bad FET in this amp before. When I changed the FET with an old FET that I had everything was fine. Since then I replaced all FET's to make sure it's more reliable. Now when I power it up the fuses blow. But they don't blow on contact, they blow after a second or two. I have measured the FET's and they all seem consistent. None of them have 0 ohms to ground or to any of the legs. The same goes for all the BJT's. Thanks
Old 18th April 2011, 07:21 PM   #2
Observation: The fuse that is closest to the middle of the amp blows immediately when the fuse is placed into holder with power connected. The other fuse blows slow when placed into holder and power connected. The remote power is not hooked up at this point. The only thing hooked up to amp is B+ and ground.
Old 18th April 2011, 10:37 PM   #3
Do you read more than a fraction of a volt when you place your meter across the first and third legs of the power supply FETs as you insert the fuse?
Are you sure that you don't have the power connections reversed?
Is anything getting hot?
Orion hcca 250r and 225r grounding out ash4kel Car Audio 3 31st March 2011 02:44 AM
kicker zr1000, orion hcca 250r, mmats d800.2, mtx6500d, mtx 942, rockford punch 45 ernie cosillos Swap Meet 2 16th February 2011 05:56 PM
Orion hcca 250r mike49504 Car Audio 4 4th November 2010 07:18 PM
orion hcca 250r schematics ernie cosillos Car Audio 20 21st October 2010 05:44 PM
Help Orion 250g4 keeps blowing fuses Jstyl Car Audio 108 30th October 2009 02:59 AM
Page generated in 0.06181 seconds (72.56% PHP - 27.44% MySQL) with 10 queries
