orion HCCA-D1200, protect mode
Old 18th April 2011, 03:23 AM   #1
nTranced is offline nTranced  United States
Default orion HCCA-D1200, protect mode
I have an orion HCCA-D1200 in my posession, I took it apart due to the amp going into protection mode. I noticed on of the FET's had a leg broken and possibly burned. The part number is FQA34N20 on the broken one. The others on the oposite side are IRFP064N's.I may have possibly damaged that one removing it from the thermal paste so it may not be the issue that killed the amp.
anybody got some tips on issues with this amp, I fix PC motherboards and chip OBD-1 Honda ecu's. I'm just doing this for a friend so any help is greatly appreciated
Old 18th April 2011, 03:49 AM   #2
joesch1999 is offline joesch1999  United States
Parts are very hard to get for one, replace all the fets I had to get them on ebay, and I could only get the irf po6 make sure you check the board next to the big caps on the right side for damaged parts as well if someone knows where i can get the fqa's please let me know
Old 18th April 2011, 04:32 AM   #3
i just checked the 100kiloohm resistors on r172, r181, r164, & r162 near the burned FQA34N20 and they are nowhere near the correct value checked on the board with a multimeter and they are all over the place. The 39 ohm resistors below them read fine.
Is there something I can substitute the FQA34N20's with thats reliable and readily available online.
Old 18th April 2011, 05:13 AM   #4
looks like the STW34NB20 is a direct replacement
STMICROELECTRONICS|STW34NB20|N CHANNEL MOSFET, 200V, 34A, TO | Newark.com
should I replace just those and the 100k ohm resistors?
Old 18th April 2011, 07:00 AM   #5
Perry Babin is offline Perry Babin  United States
Is the 34N20 shorted?
If not, for testing, solder the leg back to the board.
Why do you think the 064 was damaged?
Ebay parts are often counterfeit or substandard. Just because they work in some applications, doesn't mean they'll work in all applications. Class D amps are notoriously sensitive to changes in output transistors. Unless absolutely necessary, don't use any substitute.
Old 18th April 2011, 04:26 PM   #6
the 34N20 was bad the leg broke off not on the side connecting to the board but the side connecting to the inside of the FET The fairchild FQA34N20 transistors are impossible to find and ST lists these as a direct cross reference I ordered the ST's from newark. I'll see if it works
Old 20th April 2011, 01:58 PM   #7
The ones I got off of ebay were a direct replacement, the guy I got them from had them in old stock in the us, but I paid 10.00 bucks a piece
Old 23rd April 2011, 04:31 PM   #8
replaced the fets and inspected the resistors off the board. No audio still
orion HCCA-D1200, protect modeHide this!Advertise here!
Orion hcca 250r mike49504 Car Audio 4 4th November 2010 07:18 PM
Orion 2500D trouble shooting- protect mode Scanlines Car Audio 5 30th July 2008 10:59 PM
orion 2100 hcca mike49504 Car Audio 11 11th February 2008 02:14 PM
Orion Hcca boxcustom Car Audio 0 26th January 2007 06:36 PM
orion 250 hcca mike49504 Parts 2 19th January 2007 08:57 PM
