Working on an Earthquake 200DHC Mark 2 for a buddy and one of the RURG3060C rectifiers has snapped a leg. The part itself is still good but I would rather just replace it than try to solder the leg back together. Is there a good sub available for this part? It appears that these are hard to find
#2 |
Yeah just one but I would be willing to buy a pair if you would be willing to part with them.
#3 |
EDIT: Sorry, mine are actually RURG3020C. I don't see why a car amp would need 600V diodes though; 200V should work.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#4 |
Is it the same case style? I agree that the 600 volt may be a bit overkill
#5 |
Yeah its the exact same TO-247 case dual diode, just the 200V version.
http://www.fairchildsemi.com/ds/RU/RURG3020CC.pdf PM me your address and I will send you a couple.
#6 |
MUR3020, MUR3060
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#7 |
Does everyone agree that the rurg3020 will be a suitable replacement in this amp ?
#8 |
Well, he asked for RURG3060C which is a dual diode.
Spooney, does it have two pins or three?
#9 |
Hi Guys,
I'm guessing this is a rectifier on the output of the step-up SMPS in the amp? If so, you should really stick with the 600V rating on that part. I've seen +/-75V SMPS that had well over 400V of ringing on the diode, even with proper snubbers. 600V parts would have higher losses than a 400V or 200V part, so there's likely a very good reason they were chosen. They wouldn't be there unless they were needed. I'd bet if you put the 200V parts in there, they'd self destruct in no time. Take a look at the Fairchild Stealth line-up. There's likely one in that series that would drop in. Cheers, Owen |
#10 |
The amp has 80v of rail or less. I think the 200v would work. If they're being used in the amp that theAnonymous1 has, I'm sure that they're OK.
The rectifiers I listed have dual diodes. http://datasheet.octopart.com/MUR306...et-5402620.pdf The RURG3020 is available from Future also.
| cartridge replacement | chopchip | Analogue Source | 30 | 16th November 2010 07:20 PM |
| help with replacement tweeter replacement - KLH twenty three | indianajo | Multi-Way | 2 | 15th February 2010 12:54 AM |
| replacement for an AD1853? | 9u | Digital Line Level | 0 | 2nd November 2009 07:03 PM |
| 2SK389 replacement | Hyldal | Parts | 10 | 30th November 2007 07:21 AM |
| 2N2905A replacement | Juergen Knoop | Parts | 0 | 2nd August 2007 05:21 PM |
| Page generated in 0.09001 seconds (79.31% PHP - 20.69% MySQL) with 10 queries |
