Go Back   Home > Forums > General Interest > Car Audio
Old 17th April 2011, 04:30 PM   #1
Default EASY PASSIVE CROSSOVER QUESTION
i understand how the basic crossovers work and i use some calculators on the internet. but usaully when i hook something like this up i do not bridge the amp. in this case i will be bridging the amp which means both of outputs will have power (2 inverted signals), not one terminal with power output and one with only a reference. my question is should i install the crossover (1st order) on the positive terminal only like normal or should i have to insert a cap on both terminals? it just seems like to me that if i only install 1 cap on 1 speaker terminal there would be some sort of colflict.
Old 17th April 2011, 04:42 PM   #2
ppia600 is offline ppia600  United States
One of the bridge terminals starts out being the "+" and still is after bridging. Use it for +
Don't worry... you can always turn the gain down!
Old 17th April 2011, 08:32 PM   #3
okay. it just seems like that would only filter half of the signal going the the vioce coil
Old 17th April 2011, 10:49 PM   #4
You only need the cap on one terminal.
Old 17th April 2011, 10:55 PM   #5
cool. i got 2 of the same answer. i'm going with it. thanks!!
passive crossover basics question MCPete Multi-Way 11 30th September 2010 04:35 PM
Passive crossover/filter question dooper Multi-Way 2 26th January 2010 03:00 AM
How easy of a crossover can I get away with for this Vifa combo? Tino Multi-Way 7 5th June 2008 11:45 PM
Question/s about passive crossover and components? Toast_Master Multi-Way 24 23rd January 2008 07:09 AM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 12:14 AM
Page generated in 0.07422 seconds (71.22% PHP - 28.78% MySQL) with 10 queries
