Go Back   Home > Forums > General Interest > Car Audio
Old 17th April 2011, 03:38 PM   #1
Default rockford fosgate from argentina
hi guys! andres'm from Argentina and my amp is blown rockford the model is 250a2, wanted to know if anyone has the driagrama or blueprint. thanks!
Old 17th April 2011, 03:42 PM   #2
Rockford Corporation Technical Library CD
Here ya go all info is here
Very simple amp to fix
Old 17th April 2011, 03:50 PM   #3
If you have any problems with it let me know I have fixed 100 fosgates, the biggest thing you might have problems with it soldering the fets to the heat sink board.
here is my email joesch_1999@yahoo.com
Old 17th April 2011, 04:05 PM   #4
MyNameIsJake's Avatar
Send a message via AIM to MyNameIsJake
SWEET! Thanks for the link.
“We are no longer the knights who say ni! We are now the knights who say ekki-ekki-ekki-pitang-zoom-boing!”
Old 17th April 2011, 04:28 PM   #5
thank you very much for your help! I tell them I'm not an electrician. but with the help and guidance of you, I will encourage me to fix it.! there went up as an image diagram which are the components, the number "r 20" is? mosfet is next!
cambiare all IRF9540 and lm337sp, and two others, ie the two sides.
joesch1999 friend is feat?
Old 17th April 2011, 04:30 PM   #6
Old 17th April 2011, 04:39 PM   #7
http://194.204.29.93/rockford/techli..._pcblayout.pdf
Old 17th April 2011, 04:47 PM   #8
it uses irf z40 in the n channel, check those, check the regulators lm317 on one side and the lm337 on the other, but there has to be a bad p channel fet as well n channel 95 percent of the time blows because something is wrong in the p channel it uses a h bridge in the p channel which means p and n channel fets 9540 is the p channel fet 540 is the n channel fets check those and when you get the bad ones replaced make sure you check the zeneers off the power supply and the caps before powering it up rockford amps are not forgiving if you don't make sure everything is good it will blow them again and it takes time to solder fets to the heat sinks, don't let your hard work go to waste by powering it up before everything is right
Old 17th April 2011, 04:53 PM   #9
if you don't understand what I mean by p channel and n channel, N Channel is the front of the amp where the power converter is it's the thing that looks like a spider with leads running to the fets green and red leads, p channel is the back of the amp where the big capacitors are and backwards basically the power chip is behind those caps that also needs to be checked, but most likely is good.
Old 17th April 2011, 06:49 PM   #10
ok I get it. which is the IRFZ40?
Rockford Fosgate 150a1 mike49504 Car Audio 1 10th February 2011 07:52 AM
Rockford Fosgate T3002 DaytonaES Car Audio 1 14th January 2011 01:06 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
rockford fosgate 1000bd mike49504 Car Audio 48 17th May 2007 04:44 AM
rockford fosgate 500s mike49504 Car Audio 14 20th October 2006 06:04 PM
Page generated in 0.09858 seconds (79.04% PHP - 20.96% MySQL) with 10 queries
