Go Back   Home > Forums > General Interest > Car Audio
Old 22nd April 2011, 11:03 PM   #101
.4 ohms
Old 23rd April 2011, 12:35 PM   #102
If the TLx94 hasn't been replaced, I'd suggest replacing it. Install it in a socket if you have one.
Old 23rd April 2011, 05:56 PM   #103
it's a brand new one as of two weeks ago, I have more should I put another one in?
Old 23rd April 2011, 06:01 PM   #104
Perry I was messing with the amp last night, was checking over the sockets where the 688's go on the other side of the amp there is negative on collector and base of them, and you already know the sockets where the 718's go on the left side of the amp have positive on both sockets
Old 23rd April 2011, 10:08 PM   #105
With the voltage you posted for the IC, I don't see any reason for it to do what you stated that it was doing (essentially shorting pins 9 and 10 together when power is applied). I'd suggest replacing it. It may not solve the problem but it would eliminate it as a possible fault.
Old 25th April 2011, 02:03 PM   #106
ok I have the tl out, there is only a 220 ohm resistor separating the ground pin 7 of the ic from the outputs pins 9 and ten, the tl is o/l out of the board, pin 7 and 16 on the tl give a o/l reading on the IC
Old 25th April 2011, 05:17 PM   #107
I am getting negative 12 volts reading on pins 9 and ten with the n channel drivers out
Old 25th April 2011, 07:08 PM   #108
Make sure that you didn't have the black probe on the B+ terminal of the amp.
Old 25th April 2011, 07:18 PM   #109
yeah i didn't, is a a1268 npn bipolar? I was noticing I transistor that had been replaced before I got the amp from my friend, the base leg is connected right to the negative terminal of the amp and the collector has twelve volts emitter is putting out 7 volts, I don't think a 1268 is biploar maybe I am wrong hard to find data sheets on those korean parts. I am thinking that maybe whoever worked on this amp before used a 1268 in place of a 3198 i think thats the bipolar one, I put a new tl494 in still same voltages the 1268 is in spot q301
Old 25th April 2011, 07:38 PM   #110
Didn't what?
An A1266 is a PNP bipolar transistor. The pin configuration is ECB. The collector is likely connected to ground if this is being used as an FET driver.
The 1268 is also a BJT.
crossfire cfa-602, car audio amp problem tuneman Car Audio 29 23rd September 2010 05:08 AM
crossfire cfa-602, car audio amp problem tuneman Solid State 1 11th September 2010 01:51 PM
crossfire amp mike49504 Car Audio 4 12th January 2010 07:49 AM
Crossfire vr1000D sub amp no1stunna Swap Meet 0 21st February 2009 08:59 PM
Mirand A1 CFA-Amp (Pictures) welcome comments ! pixworld Solid State 23 11th January 2005 11:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
