Go Back   Home > Forums > General Interest > Car Audio
Old 23rd April 2011, 01:52 AM   #11
In case the pictures don't attach, go to http://farmerjg.shutterfly.com/.
Originally Posted by farmerjg View Post
Alright, sorry for the delays. I was a little off earlier. I actually have 4 wires on the speaker. I don't have the brand on the speaker, other than it's from a Chrysler van. I've also got a picture of the adapter I'm using because that's what fits on the car. So, smart people....go! How do I turn 4 wires into a 2 wire adapter.Click the image to open in full size.
Old 23rd April 2011, 02:01 AM   #12
Pano is offline Pano  United States
Pano's Avatar
You are trying to link to images on your hard drive. That's not going to work. Use the attachment button instead.
Old 23rd April 2011, 06:10 AM   #13
sofaspud's Avatar
farmerjg, you need to do a search to find the wiring diagram for your vehicle. For example, this page shows the wiring for a 2006 Chrysler Pacifica. Or at least find some way to determine which 2 wires are for the tweeter and which 2 aren't on your speaker. Can't really go any further until that info is known. And thanks for following up on the 3 wire conundrum.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 23rd April 2011, 12:58 PM   #14
It appears that it may have an amp built onto it. To use the amp, you'd have to find a wiring diagram to know which wires were 12v, ground and signal. Using the speaker without the amp may not be possible if the speaker has an impedance below 4 ohms.
Old 23rd April 2011, 02:30 PM   #15
purplepeople's Avatar
A shot of the front will tell if the speaker is 2-way or not. I suspect that it isn't but it's hard to tell if that crescent shaped assembly is covering another set of terminals. I haven't ripped apart car audio in years so I find it strange to think that there might be active speakers in modern vehicles. But it makes sense since so many advertise multiple speaker sound systems that look and sound so basic. It's certainly easier to position bunch of small amps around the car instead of wiring everything from a physically large bank of amplifiers.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 23rd April 2011, 02:49 PM   #16
Speakerholic
Cal Weldon's Avatar
I believe you will find that this is indeed an Infinity 2 way speaker with a built in half-doughnut amp. The XO is between the two drivers as is common on auto units. To find them a new location might be tough as each one is designed for a particular location in the vehicle. Now, to find a schematic...
...check here:
http://www.modifiedlife.com/request-...iring-diagram/
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 23rd April 2011, 05:15 PM   #17
Regarding things being designed for specific locations, if you're referring to the intended acoustic effect, I'm not too worried about that. This is just my truck that I take to and from workout and soccer. I just need better than stock.
In some of my research I'm also finding that what I thought was tweeter wires is likely an amp. I know somebody mentioned a limitation on the impedance. What happens if I just cut into the leads directly off the speaker (the blue and light gray) and bypass the mini-amp? Sorry if that sounds stupid, I'm just a little oblivious to how this stuff works?
Old 23rd April 2011, 06:50 PM   #18
Speakerholic
Cal Weldon's Avatar
That should work unless the amp incorporates equalization as they seem to hint in the literature. That will affect your frequency response.
Old 24th April 2011, 07:37 AM   #19
sofaspud's Avatar
I thought this was a strange looking car speaker. I wasn't aware active speakers were being used. I always get the cheapo option, then take it out for my own aftermarket rig. If it's active, then I would guess that two wires are for signal and two are for power.
This really seems to be one of those "you had to be there" cases. I'm not blaming the OP, but if he doesn't know what he has it's hard to say what to do with it. I guess the option exists to utilize the amp/speaker as is.
Adapting small drivers to a TL pjblakey Multi-Way 6 14th February 2011 08:37 PM
Adapting speakers with red/black wire connection to pc? varitek Parts 4 19th January 2007 12:47 AM
Adapting a Seas Odin for center channel jhmmdahl Multi-Way 1 30th December 2006 01:10 AM
adapting original passive crossover keyser Multi-Way 0 22nd February 2005 10:49 PM
Adapting a Car Antenna to an F coaxial Verse~Chorus Car Audio 4 13th February 2005 02:57 PM
Page generated in 0.10310 seconds (78.25% PHP - 21.75% MySQL) with 10 queries
