Go Back   Home > Forums > General Interest > Car Audio
Old 14th April 2011, 07:16 AM   #1
timwebb is offline timwebb  United States
Default Power Acoustik A2400db
i have this amp and one resistor keeps burning up. anyone repaired this amp?
the resistor at the bottom left.
Old 14th April 2011, 07:39 AM   #2
Is the Zener next to it shorted?
Old 14th April 2011, 06:57 PM   #3
the diode check tested fine. do i need to test it powered up?
Old 14th April 2011, 08:02 PM   #4
Is the resistor opening or is it simply becoming darkened?
If it's opening, how long does it take?
Old 14th April 2011, 08:36 PM   #5
it opens as soon as the light turn green.
Old 15th April 2011, 12:53 AM   #6
There's no need to have the resistor intact for this test.
With the amp off, find the end of that resistor that is directly connected to the negative speaker terminal. Place your black probe on that terminal of the resistor. Power up the amp and when the LED goes green, place the red probe on the other terminal of the resistor. What is the DC voltage? Polarity (positive/negative is important).
Old 18th April 2011, 01:30 AM   #7
ok i found the problem the guy who worked on it before used the wrong resistor.now i got one output transistor that puts the amp in protect.
Old 18th April 2011, 07:13 AM   #8
I'd replace Q124 and Q125 on the driver board with MPSW42s. Stand them off of the board near the fan blades of the cooling fan.
Also make sure that the cooling fan is running smoothly, with no vibration.
You'll need to replace all of the outputs if one failed. Don't buy them from eBay. I've had multiple amps sent to me with the 31n20s from ebay and the only problem was those transistors. They simply won't work. They run hot and fail prematurely.
Power Acoustik TS980 sparks, blows fuses even without power on. BoeroBoy Car Audio 7 30th September 2010 02:17 PM
Need output chokes for power acoustick a2400db ppia600 Car Audio 11 4th September 2009 01:43 AM
Power Acoustik Amp Help 22chet Car Audio 7 22nd February 2009 10:05 AM
Power Acoustik A2400db spooney Car Audio 21 19th March 2008 12:05 AM
Help me to fix POWER ACOUSTIK please! Mordor Car Audio 10 13th February 2006 07:58 AM
Page generated in 0.09620 seconds (79.73% PHP - 20.27% MySQL) with 11 queries
