Rockford Fosgate Power 450S
I don't think it's the RCA ground because the ground generally affects at least two channels. To confirm, you could unplug all RCAs and touch the center conductor to the center conductor terminals on the back of the RCA jack to see if it does the same thing.
If not, I'd suggest pulling the outputs out of a good channel to see if the faulty channel will work right with known-good outputs.
Well I can try replacing the ouputs again maybe one is leaking? I bought 350 of each 540 and 9540 all were new and sealed manufacturer is IR. I bought them from a well trusted electronics whole seller on ebay. I have never had any issues with the outputs I have purchased from this seller.
I will try your advice to eliminate bad outputs.
Could a leaky output cause this issue??
The 500m was drawing current when it would make the loud noise same squaling like this one is doing. I changed the switch and it quit. Its worth a try i guess. That was a mono amp thought and this is a 2 channel so wouldnt it affect both channels not just one? Could it possibly affect only one?
Yes I have seen a few like that. Always wondered why, now I know. I will put in a new switch later today and let you know the result.
As for that power 360a2 it seems to have similair problems like the 400a4 did. Maybe I should be checking resistors that are even a little out of tolerance.
For the 360, I think we need to start over (in the same thread). Reinstall all parts and post what you have.
That resistor was actually not out of tolerance. 531/589 ohms would have been out of tolerance. I don't know what the problem was but the fact that it remained cool meant that there was a problem.
