The power supply was blown when I received this amp. I got the 3205 fets but it uses 2sa1266/2sc3198 for the emitter follower pair. I was wandering if there was a good replacement for those?
#2 |
There are many options. If you're trying to use something you have on hand, list ALL of the PNP transistors you have.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
2n4403, mpsa56, mpsw56, 2n3906, mpsw92, ksa1220a, 2n5087
#4 |
Of those, I'd use the KSA1220. This is to replace the 1266. They don't use NPN drivers as far as I know.
#5 |
thanks. i haven't even pulled the board yet to really check it out. i just saw 1 that was completely destroyed and others in the area so i read all the #'s i could see.
thank you. 1 day i will have confidence to choose my own replacements. |
#6 |
would 91 ohm work for the gate resistors? 3205's
#7 |
Probably not. I'd suggest that you use 47 ohm resistors.
#8 |
i can make out the first line on 1 of the resistors and it appears to be red. so i figured that it was probably 2? ohm and all i had was a 20 and a 47. in the tutorial perry suggested 27-47 ohm so i am going to try the 47 ohm and see what happens.
#9 |
I should have looked at the photos I have. The originals are 22 ohms and would be better, in my opinion, because they were the original part. The 47s should work perfectly well.
#10 |
i got the power supply going but when i attempt to power it up it pulses on and off. i noticed the large caps C241 & C271 (200v 33uf non-polar) and c61 & C64 (80wv 4700uf) were buldging a bit but not vented. i removed and checked them, the 33uf caps measured 1 @ 32uf & the other @ 22uf and both the 4700uf caps were @ 4100uf. also i was checking the outputs and the 9640's all measured @ .800v (red probe on drain and the black on source) with diode check and 1.5m ohms on resistance. is that ok? i ask because i have new 1's on hand and they measure @ .500v & 2.5m ohms (that's what i usaully get).
was the 4100uf reading ok? the caps were at room temp when measured also i was having trouble finding some of the 200v 33uf non-polar caps. |
| Memphis 16-MCD1000 output filter capacitors | Ronode | Car Audio | 1 | 23rd March 2011 04:54 PM |
| Memphis 16-mc1000d | 807tubenut | Car Audio | 15 | 22nd December 2010 01:03 AM |
| Memphis 16-mc1000d | mike49504 | Car Audio | 46 | 9th July 2010 09:06 PM |
| Memphis 16-PR1KD | timwebb | Car Audio | 13 | 6th July 2010 10:13 PM |
| 16-st1500d memphis | timwebb | Car Audio | 27 | 23rd June 2010 07:38 PM |
| Page generated in 0.09310 seconds (80.36% PHP - 19.64% MySQL) with 10 queries |
