Looking to repair my old punch 150. Has a few componets that look to be burnt up inside the amp. Not sure what the technical name for them are but they have stamped on them "Buz11 R931" with the Motorolla logo on there also. This is going to be my first repair attempt on any amplifier and was looking for some guidance. I would like to know what I need to buy to get this thing pumping again. I believe it is an early 90's model amp 75 wats rms power at 4ohms. I think I managed to find the board number on it "Rockford cp PC-150 K3" PATENT#3883832 Thanks in advance for any and all help ya'll
#2 |
Dont have a schematic in front of me so can you post a pic of location?
I have a Punch 150 here but it is a K1 model. Does the amp power up? What are the issues the amp has? The power supply in the one I have uses BUZ 11 and the gates are IN4746 zener diodes. Sometimes Rockford used the same power supply FETS and output FETS. Please post a pic or give a little more info.................Thanks |
#3 |
Thanks for the quick reply Sean, Sorry about the lack of info...I thought that I included three pics but apparently they didn't upload. I'n not 100% sure what the gates look like but from what I can see on the board no parts with the number IN4746. Sean, do you need a pic of the location of the BUZ11, or a pic of the schematic I will try to post the pics again.
#4 |
I'd recommend replacing the BUZ11s with IRF3205s. Replace the two transistors indicated by the arrows. Also replace the resistors in the rectangles with 47 ohm resistors.
Have you checked the output transistors?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
Perry, thanks for all the pertinent info. I will read up on it tonight first and possibly check the boards transistors / outputs...after I figure out what they physically are.
#6 |
In pic 2 you have posted I would replace the orange barrel type connectors which are zenner diodes, there part number is IN4746.
| Punch 150 schematic needed | brandes.cm | Car Audio | 34 | 23rd October 2011 03:01 AM |
| Punch 150 that is stripped, is it savable? | chipper | Car Audio | 3 | 29th March 2011 04:47 AM |
| RF Punch 150 | chipper | Car Audio | 8 | 24th September 2009 12:08 AM |
| Punch 150 Butcher | 0ldSch00lf00l | Car Audio | 25 | 7th January 2009 04:59 PM |
| Page generated in 0.08286 seconds (76.06% PHP - 23.94% MySQL) with 11 queries |
