I have a Audiobahn A4801T 4-channel car amplifier it was bridged pushing 2 "10' Audiobahn 105 T SUBS bridged i had not problems for weeks until it started to go into protection mode.
I went and check all the connections and found that there were 2 resistors were fried on ch's 2 & 3 right next to the transistors located on the heat sink on each side i replaced them but could not find a PO # so i did my best with size matching I repaired the resistors and put it back together but when i plug a speaker wire in the - side on CH 2 and connect the the other wire to the positive on the the same channel or to any terminal itn acts like it surging on bogging down the jumps into protection mode On CH 3 the + is doing the same so pretty much i can plug my |
#2 |
Photo of the area around the resistors you replaced?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
This is a picture of the area around please forgive me for the bad quality don't have good camera there picture of the resistors and the back panel to show you my bridge
#4 |
#5 |
MORE PICS
#6 |
Did you replace the large resistors?
What value did you use?
#7 |
No just the burnt one could that be the issue ?
Also i know its hard but what size should the resistor be i put a 100 k ohm In as replacement they looked like the same size |
#8 |
how do i test the resistors to tell good from bad
#9 |
I can't tell much from the photos. Can you borrow a better camera?
| Purchased my 1st valve amp and can only get one channel working, please help! | moon158 | Tubes / Valves | 14 | 29th May 2011 03:22 AM |
| Right channel not working in my amp | cyclical | Solid State | 7 | 2nd September 2010 04:57 AM |
| blown/not working amp channel | Stiffmyster | Solid State | 4 | 18th July 2010 06:52 PM |
| Zen4..only one channel working.. | frankv | Pass Labs | 10 | 2nd December 2002 02:08 PM |
| First channel of Alpeh 4 is working, however... | Edwin Dorre | Pass Labs | 14 | 11th June 2002 09:22 PM |
| Page generated in 0.09117 seconds (81.88% PHP - 18.12% MySQL) with 11 queries |
