I have this Coustic 400SE amp here that is powering up in protect. There are no obvioulsy blown/shorted outputs or power supply fets even. Checked every one of them with the meter and everything looks normal there. Upon applying remote turn on power to the amp it comes on with a red light indicating protection. If you leave it on for a few minutes it will randomly try to come out of protect for a second or two and then go right back into protect. Not really sure where to start with this one. It looks like the power supply driver IC is mounted on a little vertical board in the power supply area but it has been ground down so much you can't even see the clock mark.
#2 |
Photo of the amp and driver board?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
If you have the DVD, find the following file:
/repair_tutorial/miscellaneousstuff/coustic/coustic600se/cousticamplifierdriverboard.swf
#4 |
I will get those ASAP. The driver board is similar to the coustic amp in your tutorial but has a few differences.
#5 |
#6 |
After looking at the driver board in the tutorial I am thinking that these two driver boards are essentially the same however the one in this amp doesn't have as many smd caps in it. Next time I get a chance I am going to check those caps to see if they are shorted. In any of these that you have worked on Perry did they behave like this amp as in they would power on in protect and then try to power on every so often?
#7 |
Pull the rectifiers and see if the power supply will produce output. Measure the DC voltage on the gates of the power supply FETs.
#8 |
Pulled the rectifiers and the amp powers on no problem. Power supply is functioning properly at this point. Put back in one set of rectifiers at a time(one in each supply) and narrowed the problem down to one channel. Not sure how but the first time through I missed a pair of shorted outputs(TIP35C). Clipped the TIP35c's out of the circuit and put the other set of rectifiers back in and now with all rectifiers in the amp it powers on and idles normally. So I have a channel I need to repair. Other than the outputs,drivers,and emitter resistors is there anything else in this particular amp that may need to be inspected/repaired/replaced?
#9 |
There is likely only one of the TIP35 and 36 shorted. Reinstall the two that are not shorted to see if it will produce clean audio. If it does, then you probably only need to replace the 4 output transistors.
#10 |
I will give that a shot. Thanks Perry
| old coustic 360 amp | fongman | Car Audio | 41 | 22nd December 2009 01:38 AM |
| RTA, coustic? | jol50 | Car Audio | 3 | 6th May 2008 07:22 PM |
| Coustic 801 | Tom7227 | Car Audio | 2 | 10th January 2007 06:54 AM |
| Coustic RTA 33 | 30bandgeek | Car Audio | 2 | 9th July 2006 02:31 AM |
| Coustic amp460 phhht! | anatech | Car Audio | 2 | 18th August 2005 12:49 AM |
| Page generated in 0.10187 seconds (79.09% PHP - 20.91% MySQL) with 10 queries |
