Memphis 16-ST1000D - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th April 2011, 02:01 PM   #21
With the driver boards in, you should have a 10v (viewed on the scope) signal on the gates. This would read about 5v on your meter. Subtract that from 63 and you get approximately what you're seeing.
Look at the drive signals for Q212 and Q214. How do they differ?
Old 5th April 2011, 04:13 PM   #22
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
V/Div set to 2v and 2uS
Q212 and Q214 look similar:
Q256 and Q216:
and finally Q253. If I press on the driver board the signal on Q253 turns into the same signal seen on Q212/Q214:
So there is definately something wrong or loose on at least one of the driver boards. Also some of the corners of the gate signal seem to be slightly rounded.
Old 5th April 2011, 04:36 PM   #23
There may be a bad connection in the header. You may need to remove the plastic housing and tighten the contacts (Tech Tips 7, item #6).
Old 16th April 2011, 03:23 AM   #24
Dr Zeus's Avatar
I fixed the driver board on this amp. Turned out one of the 1 ohm resistors had a crack in it. All IRF650/9650 outputs are stable and the amp is able to produce clean audio. I just got my fresh order of IRF3205 fets for the PS and just need to know if the 22ohm gate resistors are a good match?
Old 16th April 2011, 03:53 AM   #25
That's what was originally in it.
Memphis 16-ST500D mike49504 Car Audio 21 3rd August 2014 11:30 PM
Memphis 16-st1000d Componentr Car Audio 13 8th October 2012 02:01 AM
Memphis 16-MC1000D mike49504 Car Audio 17 23rd February 2011 06:51 AM
Memphis 16-ST1000D Question spooney Car Audio 4 29th December 2010 06:19 PM
Memphis 16-st1000d mike49504 Car Audio 46 19th May 2010 07:40 AM
Copyright 1999-2017 diyAudio
