Go Back   Home > Forums > General Interest > Car Audio
Old 1st April 2011, 12:24 AM   #1
Pioneer621's Avatar
Default Crunch BMX1000 amp, some parts missing
Hello everybody!
I got a Crunch BMX1000 two channel class AB amplifier a week or two ago, & although it looks like an easy one to work on, there is a part that looks to be missing I am not sure of. I will include pics so you can see what I am referring too.
It looks like a location to a capacitor but I am not certain; it is in parallel with a 1K ohm resistor, one side connects to the SECONDARY center tap of the power transformer, & the other side connects to the battery GROUND section of the board.
The location shows a capacitor goes there by the looks of it (hard to tell though), although the board number is R550, the resistor that is directly in parallel with it is labeled C550, so I think it was a mistake on the silk screen? What ever was there though looks like it burned up pretty bad & even burned a trace as someone put a solder bridge a crossed it, I cleaned the board a little before this photo.
Also, any ideas on which output transistors this amp uses or some good subs, they were taken out by the previous owner for something else, but I am mainly inquiring about the part that goes in the R550 location.
Thank you for any help on these missing parts, I greatly appreciate it.
Here are the pictures:
Solder side view of missing part:
Old 1st April 2011, 12:29 AM   #2
If you have higher resolution photos, email them to me.
babin_perry@yahoo.com
Old 1st April 2011, 01:02 AM   #3
Pioneer621's Avatar
Ok Perry, I sent the email. Hopefully I attached the pictures alright. My email starts with pioneer621, so you know where there coming from.
Thank you for the help!
Old 1st April 2011, 01:07 AM   #4
I doubt that it was ever installed.
Old 1st April 2011, 01:30 AM   #5
Pioneer621's Avatar
Ok, that makes things a little easier then, I really appreciate it man!
I will include another picture here that will hopefully be a clickable link if all else. But it was before I did any cleaning to the board at that part location & it looked like a part burned up there, as is why I thought I would ask. It does not seem like the part is a big deal so I won’t worry about it. Again, I can’t thank you enough for you taking the time to help. I’ll probably get the insulators in & make some clamps for the transistors / rectifiers & see if the power supply runs.
If I run into any other problems I will post back!
I’m curious to see if this link will be clickable & go to a decent size picture, but here is the pic of the board there before I did any cleaning & why I figured I would ask:
http://s3.postimage.org/xgw8zp94w/CR...021_edited.jpg
Old 1st April 2011, 01:37 AM   #6
It does appear that something burned there but any voltage that would have burned a capacitor (likely rated for at least 50v) would have also burned the resistor.
Also, it's not common to have a capacitor coupling the primary and secondary grounds. The 1k resistor is very common but not the cap.
Old 1st April 2011, 01:55 AM   #7
Pioneer621's Avatar
Yeah, the 1K resistor tests fine, so I don’t know if anything was ever in the other spot, but I do see what you’re saying since it seems fine.
I’m still learning on this stuff & when I see something I am not sure about I figure it’s a good idea to ask someone that does know. I’ve been trying to grasp how the amps work & the parts function in the circuit, etc. but it seems to be a slow process for me, but I still enjoy working on them, & I really do appreciate all the help.
Crunch Ground Pounder GP3000D Parts m4ick Car Audio 1 13th July 2010 12:12 AM
MTX 275x or similar series-missing parts durwood Car Audio 3 24th February 2010 12:22 AM
Missing parts of my purchase Foto Chipamp 0 13th December 2009 05:53 PM
Missing some parts from orion 225 Samuel Rock Car Audio 2 10th June 2009 01:54 AM
Page generated in 0.08191 seconds (86.54% PHP - 13.46% MySQL) with 10 queries
