Go Back   Home > Forums > General Interest > Car Audio
Old 30th March 2011, 11:28 PM   #1
ash4kel is offline ash4kel  United States
Default Orion hcca 250r and 225r grounding out
Attached are photos of the two amps. I have attempted to power the 250r only. The fuse blew immediatly on on contact. At this point I checked continuity from the ground lug of amp to the circuit board side of the fuse buss. I then checked continuity and had continuity from ground to all legs of the NDP7060's. (side note: the 225r also has continuity between the ground lug and circuit board side of fuse, and continuity to ground on all three legs of two of the NDP7060, and on two legs on five of the NDP7060's and 0 continuity to ground on the other last two NDP7060,s. Obviously I do not have consistency and I am assuming that I should not have continuity to ground on all of these. Please let me know what I should be seeing or if I am looking at the wrong thing. Thanks
Old 30th March 2011, 11:49 PM   #2
No. You should not read 0 ohms between any legs of any of the power supply FETs. You'll need to remove them to check them. To remove them, apply enough new solder so that you can heat the connections for all 3 legs at once. They should fall out when the solder is hot enough.
Old 31st March 2011, 02:24 AM   #3
Thanks Perry, One FET was bad and now it works. I will have to get some more 7060,s to replace the bad one on the 225r and test it. Thanks again
Old 31st March 2011, 02:44 AM   #4
You need to replace ALL of the 7060s if you want the amp to be as reliable as possible.
kicker zr1000, orion hcca 250r, mmats d800.2, mtx6500d, mtx 942, rockford punch 45 ernie cosillos Swap Meet 2 16th February 2011 05:56 PM
Orion hcca 250r mike49504 Car Audio 4 4th November 2010 07:18 PM
orion hcca 250r schematics ernie cosillos Car Audio 20 21st October 2010 05:44 PM
Orion HCCA 225R - Help Needed mattdg1 Car Audio 3 22nd October 2008 04:26 AM
Orion HCCA 225 vs 225R ECM Car Audio 0 29th June 2005 11:04 PM
Page generated in 0.07290 seconds (75.01% PHP - 24.99% MySQL) with 11 queries
