| Home | Forums | Rules | Articles | Store | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving |
Thread Tools | Search this Thread |
#1 |
diyAudio Member
Hello I have a Rockford Fosgate T8002 that powers up but has no audio. I found some components fried on the board and am not able to identify them. The board is PC-4698-A. The component locations are R2056, R2057, R1056, R1057.
#2 |
diyAudio Member
Check your email.
__________________
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links Last edited by Perry Babin; 30th March 2011 at 10:35 PM. |
#3 |
diyAudio Member
Thanks Perry if I am reading right they are 5.1 ohm 1 watt part # RM1-5R1F should be easy to find. I will check mouser first.
#4 |
diyAudio Member
I find nothing that must not be the part # ???? RM1-5R1F ????
#5 |
diyAudio Member
I am unsure of the package size either.
#6 |
diyAudio Member
That's Rockford's number. You'll have to find the generic equivalent.
__________________
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#7 |
diyAudio Member
It's a 2512. THIS one should be right.
__________________
#8 |
diyAudio Member
Got it thanks Perry they have been ordered.
#9 |
diyAudio Member
Also what do you recommend cleaning boards with? This one has had a pop or something sticky spilled on it need to clean it off with cleaner and a brush and blow it off with compressed air. Any suggestions??
#10 |
diyAudio Member
For sugary drinks, you'll need to use a household cleaner like 409 or Fantastik. If it's a small area, brush with a toothbrush and clean up with a paper towel or cotton swab. If the whole board needs to be cleaned, soak with the cleaner, wash with a pressure washer (car wash on low pressure) and dry thoroughly.
You can use air from a compressor but it needs to be free of oil and water (condensation). The canned air is good but not as forceful as an air compressor. Be sure to force all water from under the ICs, capacitors and connectors.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rockford Fosgate P75.2 | chipper | Car Audio | 9 | 3rd January 2011 03:20 AM |
| rockford fosgate t40001bd | bdgf2004 | Class D | 5 | 28th October 2010 06:01 AM |
| Rockford Fosgate | dtisme | Car Audio | 1 | 5th October 2010 11:39 PM |
| rockford fosgate 1000bd | mike49504 | Car Audio | 48 | 17th May 2007 04:44 AM |
| rockford fosgate 500s | mike49504 | Car Audio | 14 | 20th October 2006 06:04 PM |
| New To Site? | Need Help? |
| Page generated in 0.09397 seconds (76.63% PHP - 23.37% MySQL) with 10 queries |
