Go Back   Home > Forums > >
Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Rockford Fosgate T8002
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 2nd April 2011, 08:51 PM   #21
seankane is offline seankane  United States
diyAudio Member
seankane's Avatar
All the switches and pots operate as they should. The brake clean worked excellent on the board. I like it better than water because it evaporates so fast. The amp has been playing hard for about 15 min now NO issues.
Thanks so much !!!!
Old 2nd April 2011, 08:59 PM   #22
diyAudio Member
seankane's Avatar
Just an update, also found a faulty RCA input jack with a wiggle test. All issues are resolved and amp is still running hard......Awesome !!!!!!
Old 25th August 2016, 04:50 AM   #23
redruM is offline redruM
diyAudio Member
Hi everyone i have a rf t800.2 with board pc 4698A i need information on a couple of resistors or transistors i should say which are on Q4 and Q5 place i dont know the value of either one as they where pretty badly burnt. Any help would be greatly appreciated
Old 25th August 2016, 05:08 AM   #24
diyAudio Member
Hey there perry i need help on this same amp im working on a t800.2 i need the values for transistors on Q4 and Q5maybe a part number would greatly appreciate any info you can give me
Old 25th August 2016, 05:54 AM   #25
diyAudio Member
seankane's Avatar
Q4= MMBT3904LT3
Q5= MMBT3906LT3
__________________
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 25th August 2016, 07:51 AM   #26
diyAudio Member
Thanks sean...ill look that up right now
Old 26th August 2016, 06:27 AM   #27
diyAudio Member
Sean i have a few more r24,r31,r39and r45 plz tia
Old 26th August 2016, 06:57 AM   #28
Perry Babin is offline Perry Babin  United States
diyAudio Member
http://www.bcae1.com/temp/rockford%2...0Schematic.pdf
Old 26th August 2016, 11:48 PM   #29
diyAudio Member
I dont know the part numbers...would it be rm10 as part number? TIA
Old 27th August 2016, 12:32 AM   #30
diyAudio Member
In the future, if you need help, start a new thread.
RM/10 means that it's a 1/10 watt resistor. It will be 0805 size. These are all 10 ohms.
There are no part numbers for resistors. You have to find suitable replacements from wherever you order parts (not ebay, use mouser or digi-key).
Reply
Rockford Fosgate T8002Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford Fosgate P75.2 chipper Car Audio 9 3rd January 2011 04:20 AM
rockford fosgate t40001bd bdgf2004 Class D 5 28th October 2010 07:01 AM
Rockford Fosgate dtisme Car Audio 1 6th October 2010 12:39 AM
rockford fosgate 1000bd mike49504 Car Audio 48 17th May 2007 05:44 AM
rockford fosgate 500s mike49504 Car Audio 14 20th October 2006 07:04 PM
New To Site? Need Help?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 15.79%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Copyright ©1999-2017 diyAudio
Wiki
