Go Back   Home > Forums > >
Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Rockford Fosgate T8002
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 31st March 2011, 12:46 AM   #11
seankane is offline seankane  United States
diyAudio Member
seankane's Avatar
Well that ought to get me some strange looks huh? Pressure washing a circuit board at the car wash!! Its pretty much the whole board. Looking at the schematic you sent me do you really think those resistors could cause audio output issues?? They are linked into a circuit but end up to a ground.
Old 31st March 2011, 12:50 AM   #12
diyAudio Member
seankane's Avatar
I guess I dont understand their function.
Old 31st March 2011, 12:53 AM   #13
Perry Babin is offline Perry Babin  United States
diyAudio Member
Yes. I think I remember the same basic part (but 10 ohms) in smaller amps causing one channel to go dead when missing. You could try dropping a 10 ohm resistor in their place temporarily to see if audio returns.
Old 31st March 2011, 12:55 AM   #14
diyAudio Member
seankane's Avatar
OK I have a Punch 200.2 board I found with 4 good ones in it. I will clean the board and drop in the used ones and get back to you. Thanks Perry.
Old 31st March 2011, 02:18 AM   #15
diyAudio Member
seankane's Avatar
Ok Perry I washed the board, all I had was Kaboom so it worked ok but would not get it all off. I dont know what they spilled on it but it was some gunky stuff. I took it out to the shop and hit it with some high power brake clean and that removed all of it and quickly blew it off with compressed air from my compressor. The board looks great, but I think I will let it sit next to the stove overnight just to be safe. That will make sure there is no water in the switches and what not. I blew it off for about 5 min until I saw not even a drop of water anywhere or under anything. I will replace the resistors tomorrow and get back to you. Thanks again..................
Old 2nd April 2011, 08:19 AM   #16
diyAudio Member
seankane's Avatar
Hey Perry replaced all the 5.1 ohm resistors from a donor board. The right channel works sweet and sounds great. The left channel however not so good. Both channels bias fine but the left channel sounds muted and a little staticy, but the bias sets fine. Do you think one of the A56 or A06 smd transistors could have failed or been taken out. The resistors that I replaced in this channel were REALLY burned. I didnt find any open traces, and the output fets seem to test ok with my meter but was wondering if I should view their output through the scope? Its a small group of components so it shouldnt be hard to track down the problem....
Any thoughts????
Old 2nd April 2011, 09:01 AM   #17
diyAudio Member
seankane's Avatar
I do get sound out of the of the left channel when the amp is bridged but it does not output bridged power. It just sounds like a regular 4 ohm stereo output.
Old 2nd April 2011, 11:59 AM   #18
diyAudio Member
Have you checked the operation with the switches and pots in all positions?
If so, drive a sine wave into the amp and set the level so that you have about 20v AC output from each channel. Do this with a speaker connected if the waveform changes with/without a speaker. You'll have to tightly clamp the power transistors to the heatsink if you're going to do this with a speaker load. Post waveforms from each channel. Set the scope so that the waveform deflects 3 divisions and there are 3-4 cycles displayed.
Old 2nd April 2011, 07:39 PM   #19
diyAudio Member
seankane's Avatar
Hello Perry the T-8002 is fixed I found that the trace that runs between the 2 5.1 ohm resistors was broken away from the solder pad where the resistor solders to the board since they run in paralell. Also found a corroded faulty speaker terminal. I stock about 500 of those terminals new because they are always stripped, if you ever need any let me know. Thanks again for all your help......now back to the BD15001
Old 2nd April 2011, 07:49 PM   #20
diyAudio Member
seankane's Avatar
The output looks good and even on the scope with the voltage you posted, this thing puts out some juice, very nice sound. I really like that crossover multiplier.
Reply
Rockford Fosgate T8002Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford Fosgate P75.2 chipper Car Audio 9 3rd January 2011 03:20 AM
rockford fosgate t40001bd bdgf2004 Class D 5 28th October 2010 06:01 AM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
rockford fosgate 1000bd mike49504 Car Audio 48 17th May 2007 04:44 AM
rockford fosgate 500s mike49504 Car Audio 14 20th October 2006 06:04 PM
New To Site? Need Help?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 15.79%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
