Go Back   Home > Forums > General Interest > Car Audio
Old 29th March 2011, 04:11 AM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default Punch 150 that is stripped, is it savable?
I have a old school 1st generation Punch 150 the one with bipolar 2N6488 & 2N6491 outputs. Anyway i was given this awhile back it was already broken, missing parts i just wan't to know if it's repairable, savable? I don't wan't to throw it out or nothing i'd like to see it working again.
I tried taking pics of it so i was using my HP laptop pics aren't top notch but it should give you an idea whats up with this amp.
Feel the PUNCH
Old 29th March 2011, 04:32 AM   #2
It's likely salvageable if it doesn't have a shorted transformer. It WILL be time consuming, however.
I borrowed one of these to answer a question in another post so let me know if you need component values.
Old 29th March 2011, 04:39 AM   #3
I don't think it does i applied power to it and it did nothing. I wan't to know what MOSFETs can i use in place of the original BUZ11's? and RFP18N10? (one of them has a broken leg). And it's missing emitter resistors, driver transistor, and a small transistor located in between the FUSES. Ohh and a filter capacitor.
I'll let you know if i need some values on anything. Thanks
Feel the PUNCH
Old 29th March 2011, 04:47 AM   #4
I'd use 3205s in the place of the BUZ11s. You'll need to replace the 390 ohm gate resistors with 47 ohm resistors.
I'd also recommend replacing the two MPSA56 driver transistors. They have quite a few random failures in these older amps.
This amp has IRF3415s in place of the 18N10s.
Punch 150 schematic needed brandes.cm Car Audio 34 23rd October 2011 03:01 AM
Punch 150 outputs transistors Brain Fried Car Audio 3 7th May 2010 01:59 PM
RF Punch 150 chipper Car Audio 8 24th September 2009 12:08 AM
Punch 150 Butcher 0ldSch00lf00l Car Audio 25 7th January 2009 04:59 PM
Page generated in 0.07217 seconds (77.78% PHP - 22.22% MySQL) with 11 queries
