i have a boss dd3600 amp about a couple of days ago i noticed while i was listening to music the amp would cut off and go to protection mode and then go back to normal untill yesterday it just stayed in protection mode i checked the speaker wires they werent making any contact i checked the power,ground and remote wires they werent makin any contact at all i checked all the fuses none of them are burned out at all also i didnt get the smell of like burned at all but somehow when i connect a subwoofer on it it the subwoofer just moves.
so can anyone give me suggestions or help on how to fix this amp? i have a video uploaded so you can see the problem that im having better heres the link below.. YouTube - amp problem |
#2 |
It likely has shorted output transistors.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
can that be fixed?
#4 |
It can likely be repaired. Can you post a good quality photo of the inside of the amp?
#5 |
yea i can do that let me take a pic of it and then ill post it
#6 |
test the out put transistors for leakage...short circuit...dry joints on the solder side...
#7 |
yes, that looks like shorting in the ouput sections, likely one, or more transistors. the pulsing should be from the amps protection trying to keep it from shorting out the power supply section, and cooking the sub. don't hook the sub back up, or it can slowly cook the coil
| problem with T-amp | formula11 | Class D | 3 | 15th January 2011 12:46 AM |
| Help!The display problem on Marantz CD94&CD95. | kclai | Digital Source | 14 | 24th July 2010 10:17 AM |
| T-Amp and Pre Amp shared power problem | tedlevit | Class D | 3 | 26th February 2008 02:22 PM |
| Mosfet amp problem, Slone amp | 5th element | Solid State | 14 | 22nd March 2004 11:03 PM |
| Page generated in 0.10804 seconds (63.49% PHP - 36.51% MySQL) with 10 queries |
