ok i just put this memiphis 1000d back together and one side of the output get to warm while the other side stays cold? maybe something on the driver card?
If the audio is not clean going into the PWM board, the output can't be clean. Follow the signal through the various op-amps near the input end of the amp to see if you can determine where the signal is getting distorted.
