Go Back   Home > Forums > General Interest > Car Audio
Old 26th March 2011, 06:20 AM   #1
spooney is offline spooney  United States
Default Power Acoustik LT1440/2
Working on this amp and the outputs and power supply are blown. Original power supply fets were IRFZ44N with 100 ohm gate resistors. I have some FQP50N06's on hand that I plan on using as replacements for the power supply fets. Will 100 ohm gate resistors work with these fets? I think the drivers for the power supply are OK. The outputs in this amp are 2SC4467 and 2SA1694. Will FJA4213 and FJA4313 work good as substitutes? If they won't is there something else that may do the trick? Unsure if the drivers for the outputs are still good and I have not even looked to see what those are. Lastly there were no spring clips for the fets in this amp when I received it. Does anyone know of a source for these? I can probably make my own clamp downs but it will involve a lot of cutting,drilling,and tapping. I'd just as soon shell out the money for the clips if they can be found.
Old 26th March 2011, 03:36 PM   #2
Those power supply and output transistors should work without any problems.
As far as I know, there is no source for the clips.
Old 26th March 2011, 07:34 PM   #3
It looks like I have shorted drivers in the output section. They are using KTD600K and KTB631K for drivers. Will KSA1220 and KSC2690 work as subs for these?
Old 26th March 2011, 07:41 PM   #4
They should.
Power Acoustik TS980 sparks, blows fuses even without power on. BoeroBoy Car Audio 7 30th September 2010 02:17 PM
Power acoustik schematic brandes.cm Car Audio 11 21st January 2010 11:15 AM
Power Acoustik Amp Help 22chet Car Audio 7 22nd February 2009 10:05 AM
Power Acoustik Amp chadrock Car Audio 28 19th March 2008 05:37 AM
Power Acoustik A2400db spooney Car Audio 21 19th March 2008 12:05 AM
Page generated in 0.07452 seconds (72.29% PHP - 27.71% MySQL) with 10 queries
