Go Back   Home > Forums > General Interest > Car Audio
Old 26th March 2011, 12:56 AM   #1
seankane's Avatar
Default Rockford Fosgate BD15001
Hey Perry BD 15001 board PC-3417-D
Amp powers on and sometimes squeels inside sometimes not. Stays powered on and draws about 5 amps at idle. It will stay on as long as the gain is all the way down. If you adjust the gain while powered on the idle current just starts to drop like to 2 amps then when the gain reaches about 1/2 adjustment it draws full current from my power supply and seems like it is shorting (pops the fuse) Any ideas???
Old 26th March 2011, 01:14 AM   #2
seankane's Avatar
I know Rockford had alot of problems with their transformers whining and began coating them in later models. I dont know if it is shorted or not. Their is a massive pop when you hook up or unhook the speaker as well. You definantely do not want the speaker hooked up when you adjust the gain either WOW surprised it didnt tear my sub apart.
Old 26th March 2011, 01:25 AM   #3
What's the DC voltage on the positive speaker terminal?
Were you testing with or without a signal and speaker when it drew excessive current?
Old 26th March 2011, 01:37 AM   #4
seankane's Avatar
The dc voltage on the + speaker terminal is 0.00v dc
I was testing with no signal or speaker hooked up
I also tested with a signal and speaker hooked up with same result, but was afraid to re-test with speaker thinking it could get damaged from the severe movement.
Checked ohm reading from last leg of Q101 to speaker terminal positive and it was 0.1 ohms
It did not change when I wiggled the output inductor coil either
Old 26th March 2011, 02:42 AM   #5
Let's put this on on hold. My pea brain can't keep two such similar amps straight. When we finish with the 1000, we'll come back to this one.
Old 26th March 2011, 05:34 AM   #6
seankane's Avatar
No problem Perry very understandable lets finish the BD10001
Old 31st March 2011, 06:24 AM   #7
seankane's Avatar
OK Perry here we are again another Rockford BD. The amp looks very similar to the BD10001 so things on my end will be easier for sure. I wont have to ask you so many dumb questions this time. Where do you want to start??
Old 31st March 2011, 06:33 AM   #8
Post 4 photos of the gate signals (one from each of the 4 groups of power supply FETs - you'll read ~20 ohms between the gate legs in each group). Start with the timebase on 5us and the vertical amp on 5v/div. Adjust the timebase to display 3-4 full cycles. Adjust the vertical amp so that the waveform deflects about 2 divisions above the reference (center the trace on the reference line before beginning).
Old 31st March 2011, 06:40 AM   #9
seankane's Avatar
Will do.
Old 31st March 2011, 07:03 AM   #10
seankane's Avatar
Well if I did this right I only need to post one photo because they all look the same.
Rockford Fosgate P75.2 chipper Car Audio 9 3rd January 2011 03:20 AM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
rockford fosgate bd15001 mike49504 Car Audio 263 6th March 2010 06:52 AM
rockford fosgate p4004 mike49504 Car Audio 17 28th January 2010 07:27 PM
rockford fosgate 1000bd mike49504 Car Audio 48 17th May 2007 04:44 AM
Page generated in 0.10126 seconds (77.80% PHP - 22.20% MySQL) with 11 queries
