Go Back   Home > Forums > General Interest > Car Audio
Old 24th April 2011, 08:42 AM   #61
Mote is offline Mote  Estonia
With jumper wire connected from RCA shield to amps ground terminal I still have only 2V on op amps power supply legs. But speaker does not make any noises anymore and amp does not draw current with speaker connected.
Posted a real big resolution photo of the amps guts here:
http://mote.planet.ee/auna/auna.jpg
Maybe someone can see something which might be causing problems.
Tools: C1-76 o-scope, Weller WHS40, Mastech MAS830L multimeter, Mastech MY6243 LC meter, 16A supply
Old 24th April 2011, 09:50 AM   #62
Did you power it up like this (with the Zener out of the circuit)?
Are both of the large 220 ohm resistors getting hot?
Old 24th April 2011, 09:56 AM   #63
No, I did not power it up without Zeners.
Both 220 ohm resistors get hot.
I forgot that when I took the photos, The Zener and one op amp were out of the circuit.
Old 24th April 2011, 10:47 AM   #64
To find what's drawing the current from the 15v supply, do the following. ALL other connections to the amp MUST be broken.
Connect pin 4 of any op-amp to your 12v power supply ground. Connect pin 8 of any op-amp to the positive terminal of the 12v power supply through the 12v lamp. The lamp should limit the current and should prevent burning traces. The shorted/leaking component should get very hot very quickly.
Old 24th April 2011, 11:17 AM   #65
I let the PS run for 10 seconds and one of the op amps got hot, other 5 are cold. The one that got hot was not the one I replaced earlier and not the one I soldered PS wires to.
Old 24th April 2011, 11:59 AM   #66
Replaced the op amp which got hot with another tl072 and it works.
Sound is clear, no noise, the bad channels have never played this loud. Does not draw current.
I did not remove the RCA shield -> ground jumper though or is it safe to remove it?
Now I have to test it thoroughly to see if any other symptoms appear.
Perry Babin many thanks to you again, you are the best.
Do you use this 12V to op amps legs trick often?
Old 24th April 2011, 06:18 PM   #67
I used to use the 12v 'trick' to find defective op-amps on the older MTX amps that were prone to regulator failure. I don't use it often for other amps but it's still a good troubleshooting technique.
If you remove the jumper and the amp again has noise, try it with a standard head unit. Some amps don't work well with portable audio sources that operate off of batteries because they have no reference to ground.
Old 24th April 2011, 06:43 PM   #68
Removed jumper wire, still everything sounds good.
There is something going on with channel 1 gain pot: when adjusting volume, when I turn the pot then it kills the sound for half a second, then plays on at a new level.
I am ready to leave it be. Probably pot failure or something to do with the fact that I did not use exact same replacements for op amps.
Power tubes not drawing current redplater Tubes / Valves 1 15th February 2011 12:10 AM
Peavey 2000 Drawing huge amounts of current. andrew58 Solid State 6 20th October 2007 05:00 PM
Ground loop only when both channels connected Nuuk Solid State 16 1st April 2007 04:28 PM
Why is GND of scope channels connected to case? luka The Lounge 7 18th February 2007 07:35 AM
Simple OP amp preamp hum only with both channels connected Bing Yang Solid State 6 17th March 2006 06:23 PM
Page generated in 0.08909 seconds (75.09% PHP - 24.91% MySQL) with 11 queries
