Go Back   Home > Forums > General Interest > Car Audio
Old 25th March 2011, 08:07 PM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default Rockford Fosgate Punch 200a4
I received the amp today! I threw it on the bench it powered on fine but when i tried adjusting the front & rear gains it made the speakers jump in and out and make funny noises and i took a closer look and the pots are breaking of the board. Everything else seems to work fine except the gain pots are broken. So is there a direct replacement??
Feel the PUNCH
Old 25th March 2011, 08:17 PM   #2
Are they black Piher potentiometers? If so, Mouser has some of them. They're either 6mm or 10mm (outside diameter). They're 5k ohm pots.
Old 25th March 2011, 08:24 PM   #3
It's this one.
Feel the PUNCH
Old 25th March 2011, 08:27 PM   #4
PacParts should have them but Mouser has also begun stocking them. The value is printed on it (502)?
Old 25th March 2011, 08:34 PM   #5
They have 3B5KX2 (yeah i think it's 5k ohm) Both of them have similar part #'s.
Feel the PUNCH
Old 25th March 2011, 08:37 PM   #6
Try PacParts first if you want an exact replacement. If they can't supply it, try Mouser.
3B is the taper (log, linear, reverse log...). 5K is the value. X2 means that there are two individual pots.
Old 26th March 2011, 02:25 AM   #7
I was having a bit of trouble locating the part. Also i pushed down on the broken pots and the amp started to play music but one channel didn't play nothing.
Feel the PUNCH
Old 26th March 2011, 03:01 AM   #8
Did you call PacParts?
Rockford Fosgate Punch P325.2 mbates14 Car Audio 2 25th November 2010 03:11 AM
Rockford Fosgate Punch 325.1 Mote Car Audio 5 28th September 2010 12:51 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Fosgate Punch sub question audiomachines Subwoofers 4 18th August 2006 01:51 AM
Rockford Fosgate Punch 360a2 dawkins Car Audio 1 6th April 2006 05:27 PM
Page generated in 0.09231 seconds (69.69% PHP - 30.31% MySQL) with 11 queries
