Vibe slick A3 problem
Old 25th March 2011, 04:15 PM   #1
kirkmiles is offline kirkmiles  United Kingdom
Default Vibe slick A3 problem
My Vibe A3 amp was going into protect mode. I opened it up and after some research i tested the o/p transistors and found one of them to be reading near 0 ohms. On the transistor its marked K D998 0632. I searched around for a replacement and found a K D998 0.8D. I have replaced the damaged one with this and now amp not hitting protect mode but little to no output on channel 4(assuming this was faulty channel)? Have i fitted an unsuitable transistor? or could something else be at fault? I have some electronic knowledge/experience but im only learning Any help would be much appreciated and thanks in advance.
Old 25th March 2011, 05:26 PM   #2
Perry Babin is offline Perry Babin  United States
The problem is not likely to be due to the transistor.
Operate all potentiometers and switches through their entire range with a speaker connected to the weak channel. Does the audio play through at a normal level when operating the controls?
Old 25th March 2011, 06:37 PM   #3
I tried moving any controls and didnt seem to improve? I havent checked any other components as yet but would the amp go straight into protect mode if components were at fault?
Old 25th March 2011, 07:26 PM   #4
It depends on which component was faulty.
On the dead channel, measure the resistance from the speaker terminal that's used for bridging to the third leg of all of the output transistors. Do you read 0 ohms for two of the transistors?
Is one of the transistors the one you replaced?
Old 25th March 2011, 08:07 PM   #5
I got near 0 ohms on 2 of the transistors but wasnt the one I replaced? The one I replaced turned out to be on channel 3 and channel 4 is the one thats down???? maybe worth testing again and having a good fiddle with all the controls but I also tested it in 2 CH mode (3&4 together) and CH 3 worked but no 4? Confused...
Old 25th March 2011, 08:21 PM   #6
Can you post a good quality photo of the inside of the amp?
Old 25th March 2011, 08:53 PM   #7
Here it is
[IMG https://lh4.googleusercontent.com/_M...2/P1000207.JPG[IMG]
[IMGhttps://lh4.googleusercontent.com/_M...0/P1000206.JPG[IMG]
Old 25th March 2011, 09:49 PM   #8
Can you send me larger, higher resolution photos?
Which of the 4 groups of transistors (top left, top right...) is the dead channel?
Do you read the same DC voltage on the center legs of the output transistors in that channel as you do in the other channels?
Old 26th March 2011, 10:20 PM   #9
I get the same DC voltage on all middle legs of the transistors? Tested again and channel 4 definately dead. CH3/4 bridged seems to work? can I send you pics via email? does not seem to be letting me upload at full res?
Old 26th March 2011, 10:30 PM   #10
Got photo to upload, dead channel circled in red
All help is much apreciated
Vibe slick A3 problemHide this!Advertise here!
Lanzar vibe 266 bobomohundro Car Audio 1 31st August 2009 07:25 PM
Holey Brace and other vibe quellers 901Fixer Multi-Way 5 24th June 2009 09:45 PM
Vibe SQ12 SPACE subwoofer problem ermalak Car Audio 6 3rd April 2007 04:30 PM
Lanzar Vibe 1800D Problem, please help! manni Car Audio 3 13th October 2006 10:20 PM
A3 heat dissipation problem spTOH Pass Labs 4 3rd October 2006 05:45 AM
Copyright ©1999-2017 diyAudio
