Do I have enough power (RMS)
Old 23rd March 2011, 07:33 AM   #1
ma_tt316 is offline ma_tt316  United States
Default Do I have enough power (RMS)
My amp puts out roughly 90-100W RMS, and was wondering if I have enough juice for this CDT set?
http://cdtstore.com/hd_series/hd_62as.htm
my amp Reference Hi-Fi! Your Factory Authorized Dealer
Old 23rd March 2011, 02:10 PM   #2
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Interesting amp; I've never seen or heard of one of them before. Made in the USA in Washington too. The insides look like this amp most likely runs with sets of TIP35c/36c transistors (Darlingtons) with what looks like a regular power supply running off of two IRFZ4x fets. This amp looks a lot like my AutoTek 22 amp from back in the day.
I dont know if just one pair of TIP35c/36c has enough to what it takes to make 90w in each channel without knowing the rail voltage... but I think it should sound absolutely fine with those speakes. Nice setup btw.
Old 23rd March 2011, 02:15 PM   #3
Dr Zeus's Avatar
Woops.. Those pics are from an a90 but you posted that you have a C90. Basically the C90 is just the 4 channel version of the A90; so I presume double the parts inside.
The speakers handle 200w rms meaning you might be able to bridge your C90 amp from 4 channels down to 2 channels. It should sound good either way.
Old 24th March 2011, 08:39 AM   #4
I know the guy that designed those amps. Sure they aren't made from the highest quality parts, but they will do rated power.
Old 24th March 2011, 12:21 PM   #5
amc32 is offline amc32  United States
Actually this is a Massive Audio P200.2 the four channel version is called a P400.4.
The output and pre-drive section is the same. I have seen several models use tip 35/36 "note these are not darlingtons" and large case Toshiba. Excellent amplifier when its working properly. Slighty inflated output numbers and powersupply could use some upgrading, but all in all a better to great made Korean amp.
...............I Hear in color.................
Old 24th March 2011, 12:22 PM   #6
will post pics if anyone needs them
Old 24th March 2011, 12:32 PM   #7
is that a 1pair output stage?
Who is kidding who?
regards Andrew T.
Old 24th March 2011, 01:10 PM   #8
not much meat on this amp,but it works. Sadly though the powersupply is just as or even weaker than ouput section. Using only one fet per phase. But it works but don't abuse it. Most of the ones that I see for repair is because of the power supply fets.
Old 24th March 2011, 02:26 PM   #9
Dr Zeus's Avatar
I guess your right about TIP35/36 not being Darlingtons... Thats strange through because I thought PPI's larger Powerclass amps used TIP35/36 and I thought those amps were stated to be of Darlington design. What I know now though is there are better sounding amps than the PPI monster's I've had and worked on.
...Not to change the subject, but the OP posted up some pretty expensive speakers. Why not give them speakers the clear power they deserve?
If you want an awsome little kicking "Darlington" amp, Check out this Soundstream MC140x. I was given one for repair (See threads I've started on this forum), and I've had it in my car ever since while working out a few bugs from time to time. With all the amps I've seen on my bench, this little soundstream has beaten them all in terms of absolure SQ distortion free clean power. I wish it was a little more reliable, but I've finally fixed all the issues last month. With it I run a pair of el-cheap-o $40 DB Drive door speakers and everyone complements on how freaking awsome it sounds.
The MC140x is rated for 30x4 watts RMS, but I bridge mine down to two channels for 90w each. They use TIP101/106 or TIP102/107 outputs.
They dont come on eBay very often... but here you go.
SOUNDSTREAM MC140 4 CHANNEL SQ AMPLIFIER ~ OLD SCHOOL | eBay
Old 24th March 2011, 02:51 PM   #10
Perry Babin is offline Perry Babin  United States
The darlington configuration isn't necessarily related to the transistors used in the circuit. It's determined by the way the transistors are connected.
Do I have enough power (RMS)Hide this!Advertise here!
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Need a power a 40Watt RMS Sub... Maples Solid State 33 26th May 2004 12:32 AM
True Rms Power Workhorse Solid State 52 11th May 2004 11:44 AM
RMS Power tab30 Solid State 34 27th March 2004 05:02 AM
real RMS power Dj BASS AMP Multi-Way 8 17th April 2003 01:35 AM
Copyright ©1999-2017 diyAudio
