The MMats Juggernaut 15 has dual voice coil, Re=1.4 Ohms each. With a 1.5 Ohm stable amp you could drive a single coil for most output. Depending on the box you're gonna use you could even risk wiring them in parallel, but you can only do that if you use just the frequency range around the peak in the impedance curve... I don't think you're really experienced, so don't do that!
I just read in the manual (http://mobile.jlaudio.com/pdfs/Slash_amps/500_1_MAN.pdf) that the amp is capable of producing 500W RMS from 1.5 to 4 ohms. So, wire them in series!! BUT: Read page 14 carefully to get the most out of your amp <--
- General Interest
- Car Audio
- wiring juggernaut 15 with jl500/1 question
