Go Back   Home > Forums > General Interest > Car Audio
Old 19th March 2011, 12:04 AM   #1
ash4kel is offline ash4kel  United States
Default Orion HCCA 225 digital reference blows fuse
Hi to everyone out there. Hoping someone can help. I know it seems common for these amplifiers to "fry", but I was am hoping to learn something and help this amp at the same time. I do have electrical knowledge but not a lot in electronics, so here it goes. I have read the posts here on the forum that pertain to some of the HCCA amps. I concentrated mostly on the post about the HCCA 250 that was grounding out. I tried to follow what Perry was asking the person to do but I do not know how much of the readings pertain to my amp since my amp is a 225 with an xtr275 board. It seems to me that the fets are consistent with each other but I don't know if they are consistently good or bad. The minute I turn on the amp with the remote, it blows. I mainly am looking for what the fets should read and other other transistors to look for. Thanks in advance. Scott
Old 19th March 2011, 01:06 AM   #2
timwebb is offline timwebb  United States
this should help.
Basic Amplifier Repair - Transistor Test Applet Link
Old 19th March 2011, 12:50 PM   #3
Do you read 0 ohms between the legs of any individual transistor?
Check them Leg 1 to leg 2, 1-3 and 2-3.
Old 19th March 2011, 06:24 PM   #4
.02 ohms between legs 1 and 3 of the FET labled GI FEN16CT 9520. There is one on each side of amp.
Old 19th March 2011, 06:37 PM   #5
Those are rectifiers, not FETs. Are you sure that the numbers in the face of the rectifiers are exactly the same? They should not be.
Old 19th March 2011, 06:42 PM   #6
You are correct, they are not the same, sorry. The other is a GI FEP16CT 9520
Old 19th March 2011, 06:54 PM   #7
The K1542 FETS seem to test good. There are four 2n6491 on each side that seem good. I have four 2n6488 on one side and 3 on the other. I believe this amp has had a repair before because I have one 2n6487 in place of where the other side has an 88 in it's place. But they all seem test good. or at least no shorts.
Old 19th March 2011, 07:34 PM   #8
Remove the rectifiers and desolder the pads. Does it still blow the fuse when you apply remote voltage?
Clamp all transistors to the heatsink before applying power. Use a 15 amp fuse.
Old 19th March 2011, 08:09 PM   #9
When the rectifiers are removed and desoldered it did not blow the fuse. All I had was a 7.5 amp fuse, but it held.
Old 19th March 2011, 08:15 PM   #10
Did the solder connections appear to have the original solder connections?
Do you have anything (large 2 ohm resistor, automotive headlamp...) that you can use as a current limiter in the B+ line?
Orion HCCA 225 Digital Reference with Low Output 0ldSch00lf00l Car Audio 7 4th February 2011 04:32 AM
Orion 225 Hcca digital reference Bunn Swap Meet 0 30th January 2009 12:25 PM
Orion 225-HCCA av8rdav Car Audio 7 7th September 2008 05:50 AM
Schematics for Orion HCCA 225 D.R. tobias_svensk Car Audio 1 3rd April 2005 07:46 PM
Page generated in 0.43796 seconds (19.23% PHP - 80.77% MySQL) with 11 queries
