Just wondering if anyone had an idea why the the dc input filter caps would go on a MTX thunder801d amp, 2200uf@50V. There are 2 of these and I replaced one a few months back with a generic cap. The new cap is swollen and bad again and the one i left in is bad as well..
Could this amp survive reverse polarity and only take out theses caps or is this a heat issue? |
#2 |
The 801 has 80v caps.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
The 2200@50v looked original but it may have been replaced before. Why 80V caps on a 12v system? Back emf out of the transformer or something?
#4 |
I thought you were referring to the rail caps (which are actually 4700uf).
Many times, the primary filter caps have a significantly higher voltage than the B+ voltage. Caps with higher voltage ratings typically have lower ESR which means that they'll run cooler and will be more reliable. If you're replacing the primary filter capacitors, you need to use 105C, low impedance capacitors.
| orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, | ernie cosillos | Swap Meet | 3 | 12th February 2011 11:14 AM |
| Mtx ptp251d | mbates14 | Car Audio | 3 | 7th February 2010 02:54 AM |
| Help me fix MTX 152 and MTX 500D | hakentt | Car Audio | 94 | 8th December 2008 06:26 PM |
| MTX t9515 | ryanhb22 | Car Audio | 8 | 22nd January 2008 06:55 AM |
| mtx 1500d | mike49504 | Car Audio | 3 | 5th March 2007 01:15 PM |
| Page generated in 0.06183 seconds (75.50% PHP - 24.50% MySQL) with 10 queries |
