Hi, can anyone tell me the numbers of the two 8 pin ICs used on the driver board of the American Bass XD3000? I'm getting a noise in the output. Tried the driver board in a known good XD3000. Same problem. Thanks!
#2 |
They are probably an LM211 and a TL072. Typically, the one with the lowest circuit board designation is the TL072. I think (not sure) that pins 1 and 4 are connected together on the LM211. This may help you confirm which one is the LM211.
Are they covered with epoxy?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Thanks Perry. No they are not covered with epoxy. The numbers have been ground off. I have two of these with driver board problems. I'm needed the numbers to help with trouble shooting. The amps had output problems. I've replaced those. One board has no drive and the other is causing noise. I know it's on the board because I can put it in a known good amp and I have the samr problem. Thanks again!
#4 |
Check for poor solder connections on the transistors near the ends of the board. They often overheat and the solder oxidizes.
You should also confirm that the gates of ALL of the outputs are being driven. These amps will work even if several of the groups of outputs aren't being driven. If all aren't being driven properly, the amp won't be reliable.
#5 |
I'll be sure and check that. Thanks.
| American Bass XD1800 repair help needed | jmilch | Car Audio | 22 | 24th March 2011 03:53 PM |
| American Bass CX 1200 D | mike49504 | Car Audio | 47 | 18th January 2011 02:54 AM |
| American Bass VFL-500.1 | mike49504 | Car Audio | 5 | 7th January 2011 11:07 PM |
| American Bass CX-1200-D | mike49504 | Car Audio | 13 | 1st September 2010 03:59 AM |
| Page generated in 0.08488 seconds (76.65% PHP - 23.35% MySQL) with 10 queries |
