Amp repair question - MTX 1501D
Old 11th May 2011, 06:53 AM   #11
Gunman is offline Gunman  Russian Federation
Originally Posted by Perry Babin View Post
Post photos of the burned areas/parts.
ok, I'll try to make them. How can it help me?
Old 11th May 2011, 07:13 AM   #12
Perry Babin is offline Perry Babin  United States
If you post photos of the burned areas/parts, I can sift through the photos I have to see which best show the parts you need.
Old 11th May 2011, 07:45 AM   #13
Thanks, I'll try to make it today
But as I've sad - it's almost a half of the amp
Old 12th May 2011, 10:41 AM   #15
Is anybody here?
Old 12th May 2011, 04:56 PM   #16
the answer of mtx:
1) D260- ZENER MMSZ5250B 20V SMD SOD-12
2) D263- DIODE MMBD4148SE CATH-ANODE SM
3) D326- ZENER MMSZ5242B 12V SMD SOD-12
4) Q263- TRANSISTOR NPN MMBTA42 SMD SOT
5) FET260- MOSFET N-CH 200V 44A TO-220 9 EA P
FET245,FET246,FET247,FET248,FET255,FET256,FET257,
FET258,FET260
***FETS MUST BE MATCHED***
***DO NOT MIX MANUFACTURERS AND/OR DATE CODES ON
THE SAME AMP***
6) FET471- MOSFET N CHANNEL 75339 TO 220A 9 EA P
FET435,FET436,FET437,FET438,FET439,FET440,FET441,
FET442,FET471 ***DO NOT MIX MANUFACTURERS AND/OR
DATE CODES ON THE SAME AMP***
Old 12th May 2011, 08:03 PM   #17
Did they answer all of your questions?
Old 13th May 2011, 11:17 AM   #18
No There is a hole on the plate, You can see it on my pictures (near Q263). I must know how the elements are connected in this place from the side of the elements (upper side). Can You take the photo of this?
Old 13th May 2011, 04:57 PM   #19
I'll post a photo of both sides of the circuit board near Q263 a bit later today.
Old 15th May 2011, 01:05 AM   #20
4 photos. Sorry for the delay. I couldn't find the board.
Index of /temp/mtx1501d01
Amp repair question - MTX 1501DHide this!Advertise here!
MTX Thunder 1501D spooney Car Audio 49 16th July 2010 04:55 AM
Mtx 1501d catfishermike Car Audio 10 19th May 2010 05:56 PM
mtx 1501d ONEGGT Car Audio 0 18th October 2007 08:07 AM
