Go Back   Home > Forums > General Interest > Car Audio
Old 12th March 2011, 12:19 AM   #1
Default Needing help fixing my amp please
hi, here is the story, i've got a used jbl 300.4 car audio amplifier, it was broken, so i asked someone to repair it,
but now after 120 $ the amp is still dead.
here his what it do,
when i conect the power all inpuit/ output unpluged, the protec led light on, and 2 sec later the power led light for half a second, and then its restart...
and again and again and again ....
when the speaker are pluged i can hear some noise during the half second power.
can you help me fixing it please,
thank
jim
Old 12th March 2011, 02:09 AM   #2
well i found a shorted small transistor, will try changing it !
Old 12th March 2011, 03:09 PM   #3
ok now its playing for 2 sec then restarting do the same with and witout speaker,
what should i check ?
Old 12th March 2011, 10:12 PM   #4
Which transistors was shorted?
Can you post a photo of the inside of the amp?
Old 12th March 2011, 10:17 PM   #5
sdoom is offline sdoom  Germany
sounds like you have broken/shorted output transitors. The protection circuit senses that and turns off the power supply, ater a second the power supply circuit resets itself , the protection circuit senses a short .... Do you have a multi-meter that can measure resistance or has a diode-tester included ?
Old 13th March 2011, 12:14 PM   #6
the transistor who was shorted was in the power amplifier section,
ya i've got one multimetter, i have looked for all the transistor and none seem to be bad but i found a burned resistor in the power amplifier, maybe this is the onjly problême,
just for fun how do i test diode %?.
Old 14th March 2011, 04:20 AM   #7
What's the exact model number of the amp?
What is the part number on the face of the transistor?
Old 15th March 2011, 10:07 AM   #8
jbl px.300.4, and for the transistor i dont remember but i replaced with the same,
Needing advice on first amp repair CharlieM Solid State 2 21st January 2010 04:44 PM
Fixing Amp - No Ideas johnscustomtint Solid State 2 18th October 2008 05:02 AM
help fixing class D amp.. jton219 Class D 11 10th September 2008 04:53 PM
Need some help fixing this amp mazeroth Solid State 1 13th May 2008 03:04 AM
Help! Fixing Amp. shajan Solid State 20 29th May 2004 08:06 AM
Page generated in 0.09946 seconds (79.09% PHP - 20.91% MySQL) with 10 queries
