Go Back   Home > Forums > General Interest > Car Audio
Old 11th March 2011, 03:26 PM   #1
Rabbi is offline Rabbi  United States
Default Broken / Missing Eyelets
Just got a new amp in that a former owner tried to repair (mtx 8100d)
Whats the best way to go about amps with missing eyelets?
Would it be a viable option to just use a wire in between the part with the missing eyelet and the next part in the circuit ?
I've repaired eyelets on much more spread out circuit boards but never on an amplifier, And some of the eyelets are REALLY close to the others. Wondering how to proceed about this?
Old 11th March 2011, 03:27 PM   #2
the missing eyelets are all on power supply fets if this makes much of a difference
Old 11th March 2011, 04:00 PM   #3
Eyelets = solder pads?
Many times, they don't need to be repaired. For double-sided boards, if the solder pad is missing on the side of the board with no trace connected to it, solder from the other side of the board. For pads that are missing pads that are connected to traces, I generally use the legs from 1/8w resistors to make a loop around the leg and then connect to the trace (after removing the solder mask and tinning the trace).
Old 11th March 2011, 04:04 PM   #4
similar to this : Click the image to open in full size.
They are completely lifted out of the hole on the board
Old 11th March 2011, 04:13 PM   #5
Are you referring to the plated through-holes (vias)?
If so, that doesn't change much. The repair procedure is the same.
Is this one of the older 81000Ds?
If so, are the outputs blown?
Old 11th March 2011, 04:17 PM   #6
this is the exact thing im talking about right here, Sorry i couldn't find a picture of it before
Its the chrome 81000d, The outputs are all blown.
Old 11th March 2011, 04:20 PM   #7
What is the part number of the output transistors?
Does it have an individual gate resistor for EVERY output transistor?
Removing solder from PCB eyelets john dozier Construction Tips 26 17th January 2011 02:36 PM
Missing Resistor... TTrelease Construction Tips 6 28th July 2010 09:50 PM
HELP .. Crossover missing andrew01 Multi-Way 3 16th May 2007 08:58 AM
What am I missing? jeff mai Parts 3 19th June 2005 09:41 PM
am i missing something theChris Analogue Source 1 22nd June 2003 12:25 PM
Page generated in 0.09021 seconds (73.68% PHP - 26.32% MySQL) with 11 queries
