MA AUDIO HK-4000D ,NO OUTPUT TO SUBS
Old 7th March 2011, 04:33 PM   #1
WRENCH030380 is offline WRENCH030380
Default MA AUDIO HK-4000D ,NO OUTPUT TO SUBS
MA AUDIO HK-4000,NO OUTPUT TO SUBS
CHECKED
1- SUBS =GOOD
2-ALL FETS (MOSFETS) ARE IN THE MEGA OHMS
EXCEPT THE ONE ON THE LEFT SIDE OF THE BOARD THEY ARE IN 47.6 ? ALL ARE EQUAL THO ON LEFT SIDE, HAVE 4 FETS MSG33R AND MSG33S 2 OF EACH , CHARGDED THEM AND THE SWITCH THEY ARE ON THE RIGHT SIDE OF BOARD =GOOD
3-GOT POWER=GOOD
4-PROTECT LIGHT NOT ON =GOOD
5-NO BURNT SPOTS ON BOARD AT ALL TO OR BOTTOM LEFT OR RIGHT = GOOD
6-NOTHING LOOSE=GOOD
7-NO IN LINE FUSES=GOOD
8-DISPLAY SHOWS 13.8 VOLTS 71 DEGS AND SOUND INPUT BARS MOVING ON DISPLAY=GOOD
ANY INFO PLZ EMAIL ME AT SGTMAJWRENCH@YMAIL.COM
Old 9th March 2011, 02:02 AM   #2
mike49504 is offline mike49504  United States
Did you test to see if the amp is producing both + - rail and regulated voltages?
Old 9th March 2011, 10:40 PM   #3
No I didn't check? Do I use my meter and what setting on the meter. All I know is I had power and input but nutting to subs and the subs were test and working with a different amp on same power and input wires
Old 11th March 2011, 07:05 AM   #4
henjoyan is offline henjoyan  China
in my opinion the amp was triggered protect for some reasons,but it's a class d or class ab amplifier?
impossible is nothing
Old 11th March 2011, 02:44 PM   #5
amc32 is offline amc32  United States
check the cast metal speaker terminals at the circuit board. MA,PowerAcoustic,Audiobahn,Alphasonic ect,,, were notorious for breaking
...............I Hear in color.................
Old 11th March 2011, 10:39 PM   #6
I checked them at the bored and there connected. But I can't get a connection from the - terminal anywhere else on the board only right at the connection of the speaker - terminal. The + terminal I can get a connection all the way to the otherside if the amp I will let. Know on village at the output termials tommorow I used continuity to check the connection in the amp btw
MA AUDIO HK-4000D ,NO OUTPUT TO SUBSHide this!Advertise here!
ma audio hk-4000 ,no sound to subs ?MA AUDIO HK-4000,NO OUTPUT TO SUBS WRENCH030380 Class D 2 7th March 2011 11:38 PM
MA Audio HK-401sx current draw issue 807tubenut Car Audio 1 7th January 2011 06:28 PM
MA Audio HK-302sx power light flashes??? Redrocker Car Audio 4 6th November 2010 08:16 AM
Ma audio hk-802sx mike49504 Car Audio 14 1st July 2010 05:49 PM
Ma Audio HK 4000d works but some fets are burnt scrub50187 Car Audio 7 21st April 2008 06:51 AM
Copyright ©1999-2017 diyAudio
