Go Back   Home > Forums > General Interest > Car Audio
Old 2nd March 2011, 05:37 AM   #1
warpedhifi's Avatar
Default Pioneer GM-X862
I was given this amp to fix, and this amp has a strange problem ( I never seen before). This amp cycles power on/off very fast. The power light is constantly flashing. I checked all the fet's and outputs and everything checks out. I checked the 494 and none of the pins are reading above 5.6 volts, and all the pins are varying voltage power. The amp is getting 13.8 volts.
Any idea's???
Old 2nd March 2011, 06:17 AM   #2
Does it do it if you pull the rectifiers?
Old 2nd March 2011, 03:18 PM   #3
warpedhifi's Avatar
No, with D907 and D910 out, the amp powers up fine.
Old 2nd March 2011, 08:09 PM   #4
Reinstall the rectifiers, clamp all semis to the heatsink and power up the amp. Measure the DC voltage across each of the emitter resistors. Do any read greater than 0.000v DC when the amp is trying to power up?
Email me if you don't have the schematic diagram and want it.
babin_perry@yahoo.com
Old 7th March 2011, 01:09 AM   #5
warpedhifi's Avatar
Finally got back to this amp, and no, there is no DC voltage across any of the emitter resistors.
Old 7th March 2011, 02:31 AM   #6
Are the rectifiers shorted?
Are the secondary filter caps shorted?
Old 7th March 2011, 06:01 PM   #7
warpedhifi's Avatar
the rectifiers are good and so are the secondary caps.
Old 7th March 2011, 09:43 PM   #8
When you say that the amp powers up fine with the rectifiers out of the circuit, do you mean that the power supply drains have a clean square wave swinging from ground to about 24v?
Old 7th March 2011, 11:04 PM   #9
warpedhifi's Avatar
I checked it again, with the oscope, and with the rectifiers out of the amp. I get around 0 to 7 volts, on the PS drains.
What I was seeing before, was the power light staying on and not flickering like when the rectifiers are in. Sorry about that.
Old 7th March 2011, 11:14 PM   #10
Set the cal knob fully clockwise.
Is the gates or the drains? It looks like the gates.
pioneer gm-6100f ian33 Car Audio 2 2nd December 2010 12:30 AM
Pioneer GM-X962 warpedhifi Car Audio 2 4th July 2010 09:35 PM
Pioneer GM-40s.....again! highboy_coupe Car Audio 4 27th July 2007 05:09 AM
Where can i find Pioneer gm-x624/gm-x524 manuals? gudrun Car Audio 1 22nd February 2007 02:01 AM
Pioneer GM-X404 rkschioldann Car Audio 0 4th March 2004 11:46 AM
Page generated in 0.09035 seconds (76.56% PHP - 23.44% MySQL) with 11 queries
