Go Back   Home > Forums > General Interest > Car Audio
Old 1st March 2011, 12:18 PM   #1
Default Diy car amp??
Don't know if this is the correct place to post this thread. I want to build a car power amp to use with my head unit. Don't need any filters in it. Just need 4 channel, clean 100watts amp with remote turn on by the head unit. Sound quality is the highest priority, thats why i'm resorting to building an amp myself. I'm not an expert but can just build amps if given the circuit. I ask another friend of mine for advices as he's more well versed. Please let me know if you have any nice circuits. Thanks.
Old 1st March 2011, 02:46 PM   #2
There are all sorts of published audio amplifier designs. Some with excellent specifications and would be good DIY project's. I have a couple of books by Douglas Self that have some really great projects in them.
That said, the power supply for a automotive amplifier is going to be the trickier part to get right. There are not anywhere near as many switch mode power supply designs out in the public domain, but there is one design that is linked in the thread stickied in the top of this section, and IIRC there is one on one of Perry Babin's web pages. There is also a design at Elliott Sound Products website, with a lot of clearly written material on how to design your transformer.
I think I saw this same post by you over on diyMA and they shot you down. Don't let them discourage you. If I had the time, I would definitely give it a shot-- I still may when I catch up with every other project that I am involved in.
Good Luck,
Jason
Old 1st March 2011, 03:05 PM   #3
jol50 is offline jol50  United States
Right there are a ton of posts on amp designs here you can use, only the PS is different for a car. You can also use a car amp for the PS if you are careful or find an amp where they are easier to cut apart.
Old 6th March 2011, 04:18 AM   #4
I have used LM3886 ICs as drivers to push a pair of outputs before, and it worked quite well, simple design, and able to achieve over 100w+ depending on your outputs.
Old 6th March 2011, 05:04 AM   #5
theAnonymous1's Avatar
Here is one of many car amp schematics you can find on teh web. I actually own this amp though.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 6th March 2011, 06:59 AM   #6
May not be exactly what you want but there is a dedicated car power amp (discrete not IC) in one of the old Audio Amateur compendiums. Built for car 12 volt power etc. The book is called "Audio Amateur Power Amplifier Projects", Although a 1996 production you'll find it still for sale on the audioXpress web site in their shopping, section. Go "shopping, books, general audio, design/circuits...' I think! From memory it is a two part article with MOSFET output stage.........
Cheers, Jonathan
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 6th March 2011, 08:22 AM   #7
BrianVG is offline BrianVG  Belgium
100Watts for a car is a too much when you have efficient drivers. Perhaps you could use a T-amp for it?
Sure 4x100W @ 4 Ohm TK2050 Class-D Audio Amplifier Board
FET fanatic
DIY PSU for car amp (but for home use) BNK Solid State 18 11th November 2007 11:41 AM
car amp diy kit engel dela pena Solid State 0 12th October 2007 12:47 PM
DIY car audio class D 1500watt and above amp griff Class D 32 2nd July 2004 08:00 AM
DIY Car Amp resources fr0st Solid State 15 6th February 2004 01:57 PM
Page generated in 0.08466 seconds (76.24% PHP - 23.76% MySQL) with 11 queries
