Go Back   Home > Forums > General Interest > Car Audio
Old 22nd February 2011, 05:12 PM   #1
warpedhifi's Avatar
Default Alpine 3522
I have this Alpine amp 3522 in for repair, so far found a blown channel, replaced both outputs, went to check and amp will not power up. Here are the pin voltages off the 494:
Pin 1: 3.19 volts
Pin 2: 4.90 volts
Pin 3: 0.04 volts
Pin 4: 00.0 volts
Pin 5: 1.43 volts
Pin 6: 3.51 volts
Pin 7: 00.0 volts
Pin 8: 12.85 volts
Pin 9: 5.28 volts
Pin 10: 5.28 volts
Pin 11: 12.86 volts
Pin 12: 12.86 volts
Pin 13: 4.95 volts
Pin 14: 4.95 volts
Pin 15: 0.72 volts
Pin 16: 0.03 volts
Any idea's??
Old 22nd February 2011, 05:52 PM   #2
The IC is producing output. Are you sure that it's not producing rail voltage?
Old 22nd February 2011, 07:14 PM   #3
warpedhifi's Avatar
The amp has rail voltage, -19.5 and 20.9. checked led and found a loose connection. So the amp looks to be ok, need to check it with audio and see how it goes.
Alpine 7914 Alpine 7915 specs ? Robcrx Car Audio 4 8th September 2009 02:28 PM
Anyone with alpine for parts amc32 Car Audio 0 15th July 2009 08:35 PM
is this an alpine amp? jol50 Car Audio 30 29th April 2008 03:11 AM
Alpine amplifiers hc_TK Car Audio 3 8th February 2006 10:55 AM
Page generated in 0.06708 seconds (69.61% PHP - 30.39% MySQL) with 10 queries
