Go Back   Home > Forums > General Interest > Car Audio
Old 20th February 2011, 08:42 AM   #1
Default Sub Box Port question
Im building a box for a couple 12's and i need a 30" square opening 21 1/2" deep.
Does anyone know what need if i did pvc instead of slot ports.
If i use 3" PVC pipe how many would i need and how long do i need to make them?
Any help would greatly be appericated.
Old 20th February 2011, 11:40 AM   #2
We need more information than that. We need net enclosure volume, and desired tuning frequency. Give me that and I can give you an idea of what you need for round ports.
If you don't know tuning frequency, and I'm guessing you are going by specs for a box that the manufacturer recommends, then just tell me the net volume of the recommended box and I'll back calculate it.
I just got off midnight shift, so it will be tonight sometime before I can help if no one else can do it before that.
Later,
Jason
Old 20th February 2011, 03:38 PM   #3
spooney is offline spooney  United States
I wouldn't use 3 inch pvc pipe for ports for a pair of 12's . I honestly wouldn't use pvc at all if I could avoid it. You will have to chamfer/ round over the ends of those ports pretty good to avoid port noise. I would look into those precision port kits they sell through parts express. Two four inch versions of those trimmed to the appropriate length should work well for most people. You can use less port area with round ports because they are more efficient with the air flow.
Old 20th February 2011, 07:46 PM   #4
With enough port area, the port velocity should be low enough that there would be no noise?
If you want to leave the port tuned to the same frequency, leave the port length the same and use round ports that have the same total area as the rectangular port.
Although I may be wrong, I don't think you can use less port area with round ports. The port is tuned by the mass of the air in the port and the volume of air in the enclosure. Why would the shape of the port make a difference?
Old 20th February 2011, 08:08 PM   #5
Yeah, the port shape does not have a huge impact on anything, it is the cross sectional area of the vent that is important. As long as the port air velocity is low enough, there is not going to be audible port noise. Obviously you should take reasonable care to have a smooth uniform surface inside the vent, but you shouldn't need flares and chamfers unless your port velocity is approaching the audible range.
Port area can be reduced, but the port length will be shorter for the same tuning frequency. If port area is reduced, you need to take care that your port velocity does not get to high, but in my experience you can work with a lot less port area than most typical manufacturer recommendations and still achieve good results.
BTW, you cannot just double area and leave the length the same when you add a second driver. If your manufacturers specs say 15x15x21.5 for one driver, then you cannot just double the area to 30x30x21.5 when you add a second driver-- it doesn't work this way.
Later,
Jason
Port outside the box?? quickshift Subwoofers 3 24th November 2005 01:37 PM
Detrmining box size and port for sub regal Subwoofers 6 27th August 2005 12:36 AM
Help calculating box dimensions & port jim_vt Full Range 6 5th April 2005 04:08 AM
need a sub box port Jobe Parts 3 26th February 2004 07:19 AM
port and PR in the same box? Rory Multi-Way 15 6th September 2001 02:09 AM
Page generated in 0.09553 seconds (76.49% PHP - 23.51% MySQL) with 10 queries
