Alright, so I just picked up a used JL 500/1 supposedly in working condition, but never verified it.
So I pull out my working alpine amp, and put in the JL, hook it up and the power light illuminates like it is supposed to. However, after it has power for a few seconds there is a high pitched whine coming from the amp itself, and it has no output to the sub. The whine is still there with the RCA's unplugged, and if I unplug/plug the RCA's in, the sub makes a thud. I have the amp set to the 'baseline' settings JL suggests. This is in a dodge ram with a stock head unit. I don't know a whole lot about car audio, pretty much just the basics of how things are supposed to be hooked up and work. So I don't really know what to try to fix this or did I get screwed and this amp is just toast? I tried a different ground, same thing. Any ideas? Thank you in advance! -Aaron |
#2 |
With the amp powered up (no RCAs or speakers connected), what is the DC voltage on the positive and negative speaker terminals? Place the black meter probe on the amplifier's ground terminal. Place the red meter probe on the point where you need to measure the voltage.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
They are both right at 40.3 v.
#4 |
How are you getting signal from the head unit?
#5 |
I'm using a line-out converter.
#6 |
What make/model converter?
#7 |
Had to go double check, it's a Stinger SGN 11.
#8 |
Did you try grounding the brown wire?
If that doesn't allow the amp to produce audio, unplug the RCAs from the amp and measure the DC voltage on the input RCA shields on the amp and on the RCA cables that were plugged into the amp. Place the black meter probe on the amplifier's ground terminal. Place the red meter probe on the point where you need to measure the voltage.
#9 |
I'm pretty sure it was hooked up to ground through the deck, but I ground it to chassis just now, not sure if it matters, and still no audio.
The actual RCAs read 5.92v, the amp read .593v for red and .618 for black. Last edited by gsxtasy; 19th February 2011 at 11:15 PM. |
#10 |
I think there may be a problem with the converter. It states that it blocks DC but it doesn't appear to be doing so.
| alternator whine in PG MS2250 | marko | Car Audio | 28 | 7th May 2011 01:10 PM |
| Help! t-amp in car, alternator whine | ractis | Car Audio | 4 | 25th February 2006 04:51 PM |
| '03 Accord - Alternator Whine | Pete H | Car Audio | 5 | 30th June 2005 03:02 AM |
| Can someone help me with alternator whine? | Timbers | Car Audio | 14 | 23rd February 2004 04:14 PM |
| My 1st car amplifier!..engine whine problem. | deepanger | Car Audio | 19 | 20th October 2003 11:09 AM |
| Page generated in 0.12231 seconds (79.77% PHP - 20.23% MySQL) with 10 queries |
