Go Back   Home > Forums > General Interest > Car Audio
Old 16th February 2011, 06:12 PM   #1
807tubenut's Avatar
Default Need good pics of BXi1608
need good pics of the location around the phase shift pot, and the bass boost pot.
All my battles have been won, But the war has just begun.
Old 16th February 2011, 06:17 PM   #2
I have photos. What specifically do you need to see?
Old 16th February 2011, 06:24 PM   #3
807tubenut's Avatar
the resistor and cap values for the bass boost circuit, and the phase shift circuit, I'm adding bass boost and phase shift to a AQ1200
Old 16th February 2011, 07:05 PM   #4
http://www.bcae1.com/temp/bxi1608.zip
See if these are good enough. Let me know when you have them so I can pull them off of the server. View them at 100% to see the fine detail.
Old 16th February 2011, 07:12 PM   #5
807tubenut's Avatar
and while I'm here, I noticed on the driver cards out of a few korean amp's, there is a spot that looks like it's for a switch, says something to the effect of "ON(cant make out this letter/number)9v:OFF
got any idea what that's for? I was pondering it as being a low/high voltage override of some sort.
Old 16th February 2011, 07:16 PM   #6
Which amps have this?
Old 16th February 2011, 07:20 PM   #7
807tubenut's Avatar
got the pics, thanks Perry!
Old 16th February 2011, 07:29 PM   #8
807tubenut's Avatar
The Hifonics brutus series that iv worked on, has the card, this aq1200 (being the same pcb as the BXi1608) has it, and a few others iv done. Here is the card.
Old 16th February 2011, 07:46 PM   #9
I think I saw a transistor in that location in one amp but I'm not sure. Is it possible that it was to be used instead of the adjacent transistor?
If you can name some of the other amps that use this board, I'll see if I have photos of any of them.
Old 16th February 2011, 07:57 PM   #10
807tubenut's Avatar
It could very well be a transistor location, but not for the SMPS driver section, looks to be part of a voltage divider, Once I get this AQ back up and going, ill get some readouts on the pins.
Pics Pics and more pics New to diyAudio Les Hudson Full Range 8 7th November 2009 11:35 PM
Pics... Woofers for Sale, Cheap and Good. Please Look! Fazorcat Swap Meet 4 8th July 2006 03:59 AM
Pinoy DiY'ers, FT1600 pics..pics dranreb&* Full Range 5 3rd November 2004 10:21 PM
Some Good HQ pics of The Shorties 2.0 PaulHilgeman Multi-Way 5 29th October 2003 02:03 PM
PICS: GainClone Monoblock pics Rarkov Chip Amps 19 17th April 2003 07:37 AM
Page generated in 0.11715 seconds (73.10% PHP - 26.90% MySQL) with 10 queries
