Go Back   Home > Forums > General Interest > Car Audio
Old 16th February 2011, 02:02 AM   #1
Default Crown MT-600 - Average vs Constant Output Power?
Kindly refer to the specs below.
It states that, for "8 ohm Bridge-Mono" mode, the "maximum average power" in watts at 1kHz with 0.1% THD is 655W.
I'm quite confused with several "power" terms found in audio amplifier. For examples:
[1] RMS Power
[2] Maximum Power
[3] Maximum Average Power
Are "RMS Power" and "Maximum Average Power" the same?
Old 16th February 2011, 11:44 AM   #2
Technically, there is no such thing as RMS power. When using voltage, current, resistance... to calculate power in an AC circuit, the 'power' is average power. I'd assume that the crown amp could produce the rated power before the onset of clipping.
The term 'maximum power' is useless.
crown microtech 600 help bobcat Solid State 2 31st December 2009 01:27 AM
600/600 output transformers mobyd Parts 5 9th July 2009 06:51 AM
Crown Macro-Tech 600 problem pharaohamps Solid State 7 15th May 2008 01:02 PM
Crown Micro-Tech 600 dirtyk777 Solid State 100 24th October 2006 05:19 PM
Not your average output transformer problem Turbo7MN Tubes / Valves 7 20th February 2006 03:52 PM
Page generated in 0.06569 seconds (68.16% PHP - 31.84% MySQL) with 11 queries
