Go Back   Home > Forums > General Interest > Car Audio
Old 16th February 2011, 12:05 AM   #1
Default PPI PC4800
I got this amp in for repair and checked all outputs they seem fine. I checked all emitter resistors they check fine.
I also check the J111's they seem fine and reflowed the solder on the large transistors on the driver cards.
I still have distorted audio on the front right channel.
Any ideas where to go from here?
Old 16th February 2011, 11:49 AM   #2
Confirm that you have the same DC supply voltage (both positive and negative) on the emitters of the large SMD driver transistors on all of the boards.
Old 16th February 2011, 02:12 PM   #3
Yes i have both positive and negative DC voltages on the emitters of all large transistors on the driver boards
Old 16th February 2011, 02:17 PM   #4
Is the signal clean going into the driver board (pin 3)?
Old 16th February 2011, 02:25 PM   #5
Yes the signal looks the same as on the other 3 driverboards.
Old 16th February 2011, 02:29 PM   #6
What work has been done to this amp?
Old 16th February 2011, 02:33 PM   #7
Only thing i did to this amp was replace the 10 ohm 1 watt resistors that sit behind the rca inputs that are on the input board.
Old 16th February 2011, 02:38 PM   #8
Drive a sine wave into the amp and post a photo of the distorted waveform (preferably with a speaker connected).
Old 16th February 2011, 03:00 PM   #9
Scope set to 5ms .1 volts div and a 250hz sine wave
Old 16th February 2011, 03:21 PM   #10
What is the circuit board designation for one of the outputs in this channel?
Ppi pc2600 mike49504 Car Audio 1 28th May 2010 01:52 AM
Ppi a600 mike49504 Car Audio 3 21st March 2010 01:44 AM
PPI ART Series a404 "v" PPI Powerclass pc450 swap chemhaz Car Audio 2 21st November 2008 02:23 PM
old PPI M serie anton Car Audio 1 8th May 2007 02:32 PM
PPI vs. Alpine smokeaway Solid State 2 28th August 2005 10:51 AM
Page generated in 0.08315 seconds (77.12% PHP - 22.88% MySQL) with 11 queries
